Clutch pedal has no pressure and i cant get into gear, Whats wrong? - Honda-Tech
Old 08-30-2005, 02:42 PM   #1
Default Clutch pedal has no pressure and i cant get into gear, Whats wrong?
ok while i was driving. i had the clutch engaged while coming to a stop. suddenly the clutch lost pressure and the car died. now the clutch pedal has no pressure and i cant get into any gear. ive been hearing master cylinder. but what do you guys think? 2000 accord coupe lx
DeViuS is offline   Reply With Quote
Old 08-30-2005, 03:15 PM   #2
Diego Dangers.'s Avatar
check by the pedal to see if you have fluid inside the car, thats an indication of the master cylinder, check if there is fluid in the reservoir, check if there is fluid around the slave cylinder, check if there is fluid on the hose from reservoir to the master cylinder, those are a few probably causes.
Diego Dangers. is offline   Reply With Quote
Old 08-30-2005, 03:42 PM   #3
MestizoRacer310's Avatar
Default Re: (di3go)
I had trouble getting into gears. I was thinking at first "great, my clutch is going out." I took a look at the master cylinder...low on fluid. I put DOT3 BRAKE FLUID in and it shifted fine. If you're just low on fluid, don't fall into the trap I almost did. I found in an auto parts store a bottle of clutch fluid. DO NOT WASTE YOUR MONEY! Those bottles are smaller and more expensive. Normal DOT3 or 4 brake fluid works fine.
MestizoRacer310 is offline   Reply With Quote
Old 08-30-2005, 03:48 PM   #4
fw190bvi's Avatar
Default Re: (MestizoRacer310)
either your master cylinder is bad, the slave is bad, or theres a leak in the line. try bleeding it...if you can't get it to bleed, the master cylinder is shot. otherwise, you'll find where its leaking from.
just recently, and O ring went on my slave cylinder, causing it to leaking around the rubber boot that surrounds the fork actuator ram
fw190bvi is offline   Reply With Quote
Old 08-30-2005, 07:13 PM   #5
Default Re: (fw190bvi)
is there an o-ring by the master cylinder also? mine lost all its fluid in one day to the inside of the car, by the pedal, I refilled it and its working fine right now. any idea on that fw190?
Old 08-30-2005, 07:23 PM   #6
fw190bvi's Avatar
Default Re: (di3go)
im not sure...ive never taken the master cylinder apart. if you bled it, and refilled it, it should be fine for awhile...if you can, everytime you leave the car for a while, get under and look for dripps coming from either the area of the tranny case or drivers side firewall
Old 08-30-2005, 07:47 PM   #7
alright, I'll check my master cylinder spare that I have sitting in the car, appreciated bro
Old 08-31-2005, 09:09 AM   #8
Gen_X_Accord's Avatar
Default Re: Clutch pedal has no pressure and i cant get into gear, Whats wrong? (DeViuS)
IF you have to get a new master or slave cylinder, please get an OEM part from a HOnda dealer, dont' waste money on one from the auto parts store. I had an '86 Chevy Nova/Corolla and went through 4 master clutch cylinders because after market parts are just junk, at least for clutch cylinders they are.
Gen_X_Accord is offline   Reply With Quote
Old 08-31-2005, 09:47 AM   #9
HondaTechPro's Avatar
Default Re: Clutch pedal has no pressure and i cant get into gear, Whats wrong? (Gen_X_Accord)
Just some things to keep in mind... it is not normal for a clutch system to "use" fluid. The level will drop some as the clutch wears, but it should never run out. If it does run out, then there is certainly a leak. Most likely it is an internal leak inside the master cylinder... meaning you won't see fluif leaking anywhere, but the seal has failed. Kind of the same way if a strut goes bad... it gets realy soft but doesn't usually leak the oil out. I would recommend replacing the clutch master cylinder AND slave cylinder as a pair. The cost is reasonable, and you don't want to have to do it twice. OEM parts.
HondaTechPro is offline   Reply With Quote
Old 09-01-2005, 02:32 PM   #10
wbread99's Avatar
MestizoRacer310 kills me.... I bet tech pro backs me up on this... same thing happens with brakes: As the system gets old and people begin to clutch in ALL the way, the junk that gathers in the master cylinder destroys the seal. Once it begins to leak, thats it.... Its done. The rest of the damage is up to you!! As Racer said, all you need to do is add DOT 3 (not DOT 4, read the cap) and it'll be fine... ... except the fluid will be leaking from the master cylinder down into the driver footwell. Anyone know what brake fluid does to metal? Flinestones anyone?
While refilling the clutch resivoir will get you down the road, it wont fix the leak. You prolly should look at replacing the master cylinder if you see the leak near the clutch pedal.
Oh ya... I have 2 accords... a 94 and 95 and both had this prob.
wbread99 is offline   Reply With Quote
Old 09-01-2005, 03:19 PM   #11
Default Re: (wbread99)
Mostly very true... just to add to it... if you need to add fluid, it's leaking. Leaks don't fix themselves.... it will only get worse until it gets to the point you CAN't get it in any gear... then you'll have to pay a tow truck to get to the shop, or be without a car until you can find time to fix it.
Old 09-02-2005, 07:40 AM   #12
Schmitey's Avatar
Default Re: (HondaTechPro)
Yeah you guys are all right. My buddy and I defeated the whole purpose of bleeding his brakes when the master cylinder seals got torn apart by corrosion. From now on I hook up a vaccuum hose to the bleeder and run it into a cup of fluid so it bubbles out and I don't have to pump it all the way.
Make sure you follow the clutch line too, its pretty easy to follow and does have a rubber hose in a couple spots if I remember correctly.
Thanks for the heads up on aftermarket parts too, I'll have to keep that in mind. I know I definitely regret not keeping a honda water pump, the rebuild runs a tad hotter than the OEM.
Schmitey is offline   Reply With Quote
Old 09-02-2005, 09:25 AM   #13
Funny thing is this..........the fluid has not dropped at all since I put more in. Hasn't gone low at all. I added the fluid quite awhile ago and I've been monitoring it ever since then.
Old 09-11-2005, 01:15 PM   #14
OD4g's Avatar
I have a prelude, but this same problem, happened overnight. I checked near the pedal and no sign of fluid as if there was a leak, and the resivior has fluid in it. If there was a leak should the resivior be empty? Thats all i have checked ATM. Do you think it still might be my MC or SC? Any ideas? Thanks a lot.
OD4g is offline   Reply With Quote
DC2R clutch feels weird H.N.F Tech / Misc 5 10-01-2016 09:29 AM
DC2R clutch feels weird H.N.F Transmission & Drivetrain 1 10-01-2016 06:20 AM
Soft clutch and sqeaky noise from tranny 5speeder Transmission & Drivetrain 2 04-28-2012 10:38 AM
Clutch engages and disengages VERY low.... hybridcrx Acura Integra 3 08-09-2007 08:16 AM
clutch not engaging properly on teg... infamousALLMTR Acura Integra 4 06-30-2003 12:33 PM
Tags
95, accord, brake, clutch, cylinder, dangers, drops, empty, fluid, lost, low, master, overnight, pedal, pressure, soft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
