Clicking noise when applying brakes (HELP!!) - Honda-Tech
Old 08-16-2003, 05:22 PM   #1
Default Clicking noise when applying brakes (HELP!!)
hey guys when i step on my brakes it sounds like a clicking noise..and i cant findout what it is...i put it on the lift today at work and its not the inner or outer tie rods and my brakes are intact fully..i have a 96 accord Lx i just wanted to know if anyone has had this problem and what i could be....thanks guys
AccordOn18z is offline   Reply With Quote
Old 08-16-2003, 05:42 PM   #2
Default Re: Clicking noise when applying brakes (AccordOn18z)
make sure the tie rod is tight (strut rod) connect to the strut.......if the tie rod is tight.......
most honda brakes make clicking noise.......that normal...
im_the_teacher is offline   Reply With Quote
Old 08-16-2003, 05:44 PM   #3
cd7.h22
Guest
Posts: n/a
it could be many things it could be that one of the bolts to the rims arent on tite. your have heat strokes marks on your rotors something down there is loose so make sure everythings tight let me know wussup
Old 08-17-2003, 07:17 PM   #4
gooberwolf's Avatar
it could be the wheel bearings - that was the case w/ my 92 accord.
gooberwolf is offline   Reply With Quote
Old 08-18-2003, 11:32 AM   #5
cd7.h22
Guest
Posts: n/a
Default Re: Clicking noise when applying brakes (gooberwolf)
how hard was that to fix and did you fix it yourself im starting to hear clicking noises when i drive slow now too damn JINXED
clicking noise hendog12c Honda Prelude 11 01-01-2010 09:01 AM
Weird clicking noise phyzJunkieCivic Honda Civic / Del Sol (1992 - 2000) 2 04-03-2007 05:50 PM
Outer tie rod will it cause a clicking when braking? Spence Honda Civic / Del Sol (1992 - 2000) 1 07-18-2005 04:55 PM
Outer tie rod will it cause a clicking when braking? Spence Suspension & Brakes 3 07-18-2005 04:38 PM
Clicking noise coming from the front right? spencedogg Honda Civic / Del Sol (1992 - 2000) 22 06-04-2003 10:15 PM
Tags
2003, accord, applying, brake, brakes, breaks, clacking, click, clicking, honda, noise, rear, sound, step, ticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
