Is the rear lower than the front on a 1.25" drop all around?
Old 08-17-2003, 11:55 PM
ShaolinRider's Avatar
Default Is the rear lower than the front on a 1.25" drop all around?
Just as the Title says, I have a friend that swears that with my drop, my rear sits lower than the front. I have a 94 accord and did the drop with the 1.25" tokico setup. I think it looks perfect but just wanted to see if he acutally knows what he is looking at and talking about. Thanks in advance.
Old 08-18-2003, 05:45 AM
DrunkNRacer's Avatar
Default Re: Is the rear lower than the front on a 1.25" drop all around? (ShaolinRider)
usually.. with most applications.. on accords (or most Front-engine vehicles).. the front sits lower than the rear.... if you really want to find out.. just measure the tire from the top of the wheel well..
Old 08-18-2003, 08:23 AM
amin n'rangwa edanea
fluxion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShaolinRider &raquo;</TD></TR><TR><TD CLASS="quote">Just as the Title says, I have a friend that swears that with my drop, my rear sits lower than the front. I have a 94 accord and did the drop with the 1.25" tokico setup. I think it looks perfect but just wanted to see if he acutally knows what he is looking at and talking about. Thanks in advance.</TD></TR></TABLE>
normally the springs are set to give the front a little more suspension travel because of the engine making the front much heavier than the rear.
Old 08-18-2003, 09:30 AM
Default Re: Is the rear lower than the front on a 1.25" drop all around? (fluxion)
dayam...so you mean that hes right? sorry to bump this useless topic back up top again.
Old 08-18-2003, 09:43 AM
Nick M's Avatar
Default Re: Is the rear lower than the front on a 1.25" drop all around? (G-villeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">usually.. with most applications.. on accords (or most Front-engine vehicles).. the front sits lower than the rear.... if you really want to find out.. just measure the tire from the top of the wheel well.. </TD></TR></TABLE>
you have that backwards
the front has more ground clearance and more fender gap to clear bumps to protect the drivetrain
Old 08-18-2003, 11:01 AM
Default Re: Is the rear lower than the front on a 1.25" drop all around? (Nick M)
I understand.. initially.. on a stock vehicle, the front does sit a tad bit higher.. thats why, with most applications.. the front should be lowered a bit more.. my Tein's lowered the front like .5" more. Thus, leveling out the balance of the car.
P.S - id rather have the front lower than the back..
dakid88
Suspension & Brakes
06-21-2009 05:56 AM
onnoff7
Suspension & Brakes
04-18-2006 11:48 PM
Interlude99
11-30-2004 01:55 PM
crxsiperf
49
06-14-2004 03:44 AM
Zulu888
05-01-2003 10:08 AM
Quick Reply: Is the rear lower than the front on a 1.25" drop all around?
