Check engine light wont shut off, even after i fixed the problem the code put out - Honda-Tech
Old 01-20-2010, 09:41 AM   #1
New User
jayrod7's Avatar
Icon3 Check engine light wont shut off, even after i fixed the problem the code put out
Can anyone help me! My car has had the check engine light on since i bought it....the code kept saying its the O2 sensor...i replaced both O2 sensors and the check engine light wont shut off...i've done this multiple of times...i even unplugged the computer and the light goes off for about a minute, then it comes back on....i have a 99 honda accord....and as of right now it keeps failing inspection...
jayrod7 is offline   Reply With Quote
Old 01-20-2010, 12:25 PM   #2
tamadrummer1120's Avatar
Default Re: Check engine light wont shut off, even after i fixed the problem the code put out
which 02 sensor?
the code may come up as the primary or secondary 02 sensor, yes, but other problems could be causing it. more info needed.
tamadrummer1120 is offline   Reply With Quote
Old 01-20-2010, 12:32 PM   #3
GhostAccord's Avatar
What is the specific DTC code number? P****
GhostAccord is offline   Reply With Quote
Old 01-20-2010, 02:56 PM   #4
PilotOnDubs's Avatar
check your wires at each o2 sensor conector on the harness side. sometimes the wires back out and cause a loose connection, causing a check engine light
PilotOnDubs is offline   Reply With Quote
Old 01-20-2010, 06:33 PM   #5
redbull-1's Avatar
If your Accord has the F23A1 engine, the pre-cat oxygen sensor is a regular oxygen sensor.
If your Accord has the F23A4 engine (ULEV), the pre-cat sensor is an Air/Fuel Ratio sensor.
Post the DTC code. Also check whether you have the F23A1 or F23A4 engine.
redbull-1 is offline   Reply With Quote
Old 01-21-2010, 08:24 AM   #6
New User
jayrod7's Avatar
The code is P1167....i replaced the O2 sensor before and after the cat converter, and still the light stays on....my engine is F23A...I had a F23A4 engine (ULEV) and the code was the same, then that engine blew and i had it replaced by a honda mechanic to a F23A, and the code still read P1167...and even then i replaced both the primary and secondary O2 sensors...could it be my computer is messed up?
Old 01-21-2010, 11:57 AM   #7
a short to ground in the blk/yel alternator wire could cause the ecu to set a p1167. and blow the #6 (15 amp) fuse in the dr's under dash fuse box.
so, check and repair the alternator wire if need be and replace the blown fuse
Old 01-21-2010, 01:37 PM   #8
redbull-1's Avatar
It may be the wrong sensor. See this thread:
http://www.honda-acura.net/forums/sh...90#post4451990
Old 01-21-2010, 01:50 PM   #9
redbull-1's Avatar
Check to see if the mechanic did something to the wiring for the sensor. The F23A4 you had previously had an Air/Fuel Ratio sensor.
Old 01-21-2010, 02:45 PM   #10
New User
Bryckhaus's Avatar
I just went threw the same problem i have the f23a4 you need a certin o2 sensor for ulev that the auto parts stores dont carry and if they do they to get you for up to $300. I got the right one on amazon new for $104
http://www.amazon.com/gp/product/B00...ss_T15_product
Bryckhaus is offline   Reply With Quote
i need help and input!!!!! matt45103 Honda Accord (1990 - 2002) 0 09-18-2012 02:25 PM
engine suddenly stops ? ? ? chikichimo Honda Civic / Del Sol (1992 - 2000) 36 02-02-2012 03:45 PM
Car intermintely shuts off while driving... AznInvasion Honda Civic / Del Sol (1992 - 2000) 4 08-20-2009 03:33 PM
srs warning light dansaleen_04 Honda Accord (1990 - 2002) 4 06-28-2006 01:06 PM
Skunk 2 stage 1 cams 00EM1Si Honda Civic / Del Sol (1992 - 2000) 9 01-14-2004 10:03 PM
Tags
02, check, description, engine, f23a4, fixed, harness, honda, light, o2, oddessy, problem, reasons, sensor, shutoff, shutting, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
