check engine light not illuminating at startup
Old 01-16-2015, 02:29 PM
joey_B's Avatar
Default check engine light not illuminating at startup
I have a 1998 accord V6 and the check engine light is not illuminating when starting the car. However, if I turn the key 1/2 way just to illuminate the dash without starting the engine the check engine light will light up. This shows me that the bulb is not burnt out. Any idea why the CEL will not light up when actually turning the car on?
Old 01-16-2015, 02:30 PM
GDD Member
slomofo's Avatar
Default Re: check engine light not illuminating at startup
It's not supposed to stay on when you start the car, only when the key is on and engine is off.
Old 01-16-2015, 02:41 PM
joey_B's Avatar
I understand that its not supposed to stay on. It doesn't come on at all when starting the car. However, I can tell that the bulb is not burnt out, because if I turn the key half way (without turning the engine) the bulb will illuminate). It should come on for ~2 seconds and then turn off if no issue is detected.
Old 01-16-2015, 04:04 PM
GDD Member
slomofo's Avatar
I understand what you're saying, but I don't think you understand that I understand.
Understand?
Key on, engine off - CEL will illuminate for two seconds, then turn off.
Key on, engine off - CEL not suppoosed to illuminate.
Old 01-16-2015, 04:32 PM
holmesnmanny's Avatar
It only comes one for a couple seconds when you turn the key on to let you know its checking for errors. Then it shuts off.
Old 12-23-2015, 05:47 PM
fixauto4b's Avatar
on this topic, i have a 2000 Acura TL... Honda similarity. not starting on key turn. MIL/CEL never lights... nor does immobilizer key. i do have most other dash light coming on during key to on/start. i have been troubleshooting an ACG S fuse blowing and fuel pump never gets engaged, but realized that these lights never come on, so concerned their circuits are causing/contributing to no start.
any thoughts?
danuska17
08-01-2017 07:19 PM
butter99
15
12-18-2008 04:27 PM
jakscivic
05-14-2005 01:49 PM
CTR_EK9
02-14-2003 11:01 AM
Quick Reply: check engine light not illuminating at startup
