ride height ?'s
Old 07-03-2011, 02:10 PM
forestcd6's Avatar
Default ride height ?'s
so i just put a set of k-sport lowering springs on my car and the front end wheel gap to the fender is huge and the rear end looks correct what could case this to happen. I have double checked the springs to ensure they were installled correctly the fronts are in the front and rear in the rear. I am using stock shocks/struts. Is this normal for accords? I am thinking of cutting a coil off the front springs as well.
Old 07-03-2011, 07:05 PM
bzmotoninja1983's Avatar
Default Re: ride height ?'s
Try swapping springs from ffront to rear....
Bz
Old 07-04-2011, 08:15 AM
Premium Member
Aradin's Avatar
The front/rear springs should not at all be interchangeable. The rear springs are much thicker/wider and the front ones are thinner. My suspension "settled" after awhile and the whole car got lower than the initial drop eventually.
Old 07-04-2011, 08:34 AM
that and these springs might not be matched? i.t. the spring rates are the same for front and rear as opposed to something like 475f/275r.....
the only reason i said to switch thwem, a friend of mine had a 99 eclipse and installed front/rear backwards. it looked cool though.
Bz
Old 07-04-2011, 12:22 PM
forestcd6's Avatar
i have the thinner springs in the front and the wider thicker springs in the rear. It has been over a month and they still haven't settled. I am thinkin of cutting a coil off in the front should eliminate the gap. and not harm the ride since it is only one coil
Old 07-05-2011, 06:19 PM
Hondero_PR's Avatar
check you upper ball joint arm where is hitting. I'm having the same problem. My left side sits right and my left side is higher. I noticed my upper ball joint arm is hitting the top part of the inner fender. Check your spring rate and check how your car goes down when you lower you jack. If anyone knows a resolution to my problem would be appreciated.
vega5415
11
03-18-2014 11:14 PM
hateshino
Suspension & Brakes
06-09-2010 10:56 AM
crxtuner0
Suspension & Brakes
09-15-2009 03:41 PM
apm
Suspension & Brakes
23
04-11-2006 09:22 PM
nicksweetlude
08-06-2002 07:07 AM
Quick Reply: ride height ?'s
