CEL P0401 - Insufficient EGR Flow
Old 02-19-2012, 09:44 PM
kitt's Avatar
Default CEL P0401 - Insufficient EGR Flow
Hi guys. My 1999 Honda Accord set the CEL P0401 code (insufficient EGR flow). I reset the CEL and it came back a few weeks later (I think it was a warmer day than the previous days). Anyways, I'm getting about 21 MPG city (I know clogged EGRs can reduce fuel efficiency), is that particularly low?
I've seen some tutorials/videos (none specific to my model). I haven't seen anything that was that good explaining the process. Also I've seen people clean out their whole throttle body / intake manifold which looks pretty complicated.
It doesn't look like I can reach 1 of the 2 bolts (the one closer to the manifold) without removing other parts out first. Should I just take it to the shop?
Old 02-22-2012, 06:20 PM
ricebike's Avatar
Default Re: CEL P0401 - Insufficient EGR Flow
http://www.hondaaccordforum.com/foru...-accord-31002/
and
https://honda-tech.com/forums/honda-accord-1990-2002-2/f23a4-ulev-2691467/
and
http://www.driveaccord.net/forums/sh...ad.php?t=31865
and
cleaning the throttle body valve is much easier than this in comparison
Old 02-22-2012, 10:45 PM
h0p3l355dork's Avatar
Cleaning helps but in the end, I had to replace the EGR altogether to make my P0401 go away on my 99 accord :/ There's a cleaning procedure that requires taking off the entire intake manifold. Check that one out.
Old 02-23-2012, 05:33 AM
ricebike's Avatar
already stated in one of the 4 links i posted
be sure to rule out the passageways and vacuum hoses first before replacing the valve
try blasting the valve itself with some carb cleaner as well
Old 02-23-2012, 03:58 PM
lowcd5's Avatar
i had the same problem on my 96 i replaced the egr and that wasnt the problem so talked to a guy that helps work on my cars and we found out that the egr ports on the intake under the fuel rail were full of carbon
hondaowner82
03-27-2011 02:30 PM
Quarter Performance
09-19-2010 03:48 PM
cpgottabuh
07-11-2008 11:35 AM
Quick Reply: CEL P0401 - Insufficient EGR Flow
