CB7 IGNITION NO SPARK PROBLEMS
Old 01-19-2015, 03:42 AM
NWsleeperswaps's Avatar
Icon2 CB7 IGNITION NO SPARK PROBLEMS
So check this out i have a 1990 accord 5 speed. It acted like the coil went out.
It cranks but doesnt start. Has fuel but no spark.
Here's where I'm at with it:
rebuilt the distributor with new coil, ignitor, cap, and rotor.
the main relay clicks, runs the fuel pump, and clicks it off
no cel codes
gets power to coil and ignitor
this leads me to believe im looking at one of three things; either a grounding issue, a bad crank position sensor, or an issue in the wiring.
Any ideas?
Old 01-19-2015, 03:47 AM
Default Re: CB7 IGNITION NO SPARK PROBLEMS
forgot to mention timing belt, engine timing, and compression are good. was running fine, now its not.
Old 11-24-2015, 12:31 AM
Forgot to ever update this thread. The culprit was indeed a bad ground. It was the thermostat grounding point.
e-roc88
11-01-2010 03:39 PM
thunderlips
08-28-2009 01:29 PM
SkIp_Civic_Ek6
06-25-2006 04:54 AM
primal cb7
05-29-2005 09:38 AM
infinate bound
03-19-2004 02:25 PM
Quick Reply: CB7 IGNITION NO SPARK PROBLEMS
