cb7 coolant draining question
Old 11-26-2010, 11:44 AM
usdmftw's Avatar
Default cb7 coolant draining question
i got a 1992 accord, f22a engine. i am looking for a plug or similar to drian the coolant out of the block. i know b series they have one right on the front of block(exhaust side) but i cant seem to find one on the f22. or does anyone know a way to drain the coolant out of the block, around sleeves, coolants passages, etc. if someone could help that would be great, thanks
Old 11-26-2010, 12:31 PM
poorman212's Avatar
Default Re: cb7 coolant draining question
Back side, around oil filter, there is a drain bolt for the block. Sorry don't have any pic's handy.
Old 11-26-2010, 12:50 PM
usdmftw's Avatar
only one i could find was allen head right under oil filter but it was oil. is it above the oil filter? is it allen head or reg. socket? gonna go check again.
Old 11-26-2010, 01:59 PM
redbull-1's Avatar
See thread:
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-drain-coolant-92-accord-block-2673337/
Old 11-26-2010, 03:07 PM
usdmftw's Avatar
thanks alot redbull, how come that did not come up in my search? what keywords you use?
Old 11-26-2010, 03:15 PM
redbull-1's Avatar
"Redbull-1" posts, lol. I remembered I posted it before.
Old 11-26-2010, 08:09 PM
nus_dogg's Avatar
Yup, the bolt is located behind the block and the bolt is pretty big in size(thats what she said).
Old 11-27-2010, 01:17 PM
usdmftw's Avatar
well now new problem, the bolt is stripped out. i have tried everything i can think of except the "gator grip" lol. does not look like i will be able to get out with the motor in the car. anyone know of a different way to remove the water from around the sleeves(without removing the head)? anywhere i could get access to a water passage and siphon it out?
Old 11-28-2010, 04:16 AM
poorman212's Avatar
Can I ask why it is important to get this out?
Old 11-28-2010, 06:04 AM
usdmftw's Avatar
got a hairline crack in the block and need to remove the water so i can have it welded. the crack is on a water jacket i gues, right behind header on exhaust side of block. i tried to braze it with hts-2000 rod but when you heat it up a little bit of water seeps through the crack.
Old 11-28-2010, 07:24 AM
poorman212's Avatar
Ouch.....Pull a freeze plug and siphon?????? If the bolt won't come out, about all I've got. Good luck.
Old 11-28-2010, 03:31 PM
My02accord's Avatar
could always flip the car on its side
jk
Old 11-28-2010, 04:48 PM
kageshin's Avatar
well.....is there anyway you can tig-weld a piece of something to the bolt???....or you might have to take it to a shop and see
Old 11-29-2010, 05:29 PM
usdmftw's Avatar
prob could not get to it to weld something to it, what would cranking the car with hoses off do? would the water pump shoot the water out? i mean i know at thermo housing the water in coolant passage on back of block would shoot water out, but will it suck the water out from around cylinders/waterjackets? dumb question but at this point i just want the water out.
JVH
Honda Fit
04-01-2011 12:41 PM
missionaryrider
01-15-2010 08:23 AM
JJexpress
01-01-2009 10:37 PM
IggyBcool
02-18-2005 07:11 PM
fwdftw
09-26-2004 08:36 AM
Quick Reply: cb7 coolant draining question
