catalytic converter bolt size - Honda-Tech
Old 11-30-2007, 05:35 PM   #1
pa_itr's Avatar
Default catalytic converter bolt size
I did a search and only found that they are studs and pressed in or whatever.
I need to know the size of the bolt/nut.
My mom's 99 accord had two nuts come off from the bolts connecting the b-pipe to the catalytic converter and it's hella loud.
Just trying to head to wal mart and pick up the right nut so I can make her car quiet again.
Thanks.
pa_itr is offline   Reply With Quote
Old 11-30-2007, 06:05 PM   #2
sonicxtacy02's Avatar
i wanna say they are 15mm bolts.. but dont take that as guarantee. I doubt they'd have that bolt size at a walmart
sonicxtacy02 is offline   Reply With Quote
Old 12-10-2007, 01:15 PM   #3
pa_itr's Avatar
They are more punches than anything....not really bolts....my mechanic looked at it again and said I was correct and welded it shut.
No big deal. $20.
1991 CRX HF cat converter need help Trenton Jardine Honda CRX / EF Civic (1988 - 1991) 4 10-14-2016 02:27 PM
Exhaust Pipe Stan Moore Honda Civic / Del Sol (1992 - 2000) 3 02-21-2015 12:22 PM
integra catalytic converter garod82 Acura Integra 15 09-08-2014 10:30 AM
catalytic converter bolts tony Acura Integra 3 01-31-2013 06:23 PM
cat-conv bolt sizes RACEPAK Honda Civic / Del Sol (1992 - 2000) 1 11-25-2004 04:47 PM
Tags
accord, bolt, bolts, cat, catalytic, civic, converter, converters, honda, needed, nut, nuts, prelude, pressed, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
