Check engine Light problems
Old 12-10-2007, 01:04 AM
preynolds2's Avatar
Default Check engine Light problems
I have a 1996 Accord.. I basically created my own problem by listening to some friends. I had to change out my exaust pipes from cat. converter back to muffler. During this time.. my converter was hollowed out. yep.. anyway. After this.. my check engine light stays on. Does anyone know how I could fix this problem.. without buying a new converter? Also.. my oxygen sensor was unhooked for a short time after this.
Old 12-10-2007, 03:21 AM
He knows where you live!
TheMuffinMan's Avatar
Did you hook the O2 sensor back up?
It's probably reading funny since you gutted the cat and unplugged it.
Swing by an Advanced Auto or NAPA that does free CEL readings and find out what it's for and then they can clear it.
Old 12-10-2007, 12:30 PM
kchungb17a's Avatar
Default Re: (TheMuffinMan)
If you gutted your cat then that is why the CEL light is on. If you pulled the code I'm sure you'll find P0420 for catalyst inefficiency. There is a kit that you can buy to fool the computer into thinking the cat is still there. Google "O2 sensor simulator" and you will find something that will work. But replacing the cat is the best bet. You bring your emissions level back to normal, which is good. And gutting the cat is not a guarantee for power increase.
freddysEF
02-11-2008 08:59 PM
almostboostedgsr
03-01-2007 06:08 AM
integraftw98
10-16-2006 07:06 PM
Melman872
11-29-2005 08:54 AM
techboy3244
06-03-2003 04:15 PM
Quick Reply: Check engine Light problems
