Castrol EDGE?
Old 02-11-2010, 09:00 AM
nhldogg's Avatar
Default Castrol EDGE?
I know that there are alot of posts about which oil and what to use but i was wondering which oil filter i should use if i switch to Castrol EDGE since it is good up to 15,000 miles. I have a 1998 Accord V6 with 150,000 and i have been running Castrol GTX High Milage since i bought it with 138,000. And also would i be able to switch between synthetic and conventional oil without causing damage to the motor?
Old 02-11-2010, 12:44 PM
nicolaselias's Avatar
Default Re: Castrol EDGE?
NO OIL can be verified as being good up to 15,000 miles without a oil monitoring system or regular testing with labs such as blackstone...
That said, read any of the oil threads, there are thousands about swithcing from dino to synthetic... Even 2 or 3 recent threads....
Finally, if you really want to push your oil that long (which i don't reccomend) I would go with a Mobil1 Filter.. They are one of the best you can get for the money..
A nice alternative would be buy 2 Purolator PureOne filters, run each for half the length of time and then just change the filter halfway (and add a qt of oil)..
Anyway final statement, DO NOT do 15,000 without letting blackstone verify your oil after say 7500
Old 02-11-2010, 04:27 PM
nhldogg's Avatar
Alright thanks for the imput. I beleive that i will stick with the GTX high milage.
yujintheman
Honda Civic (2006 - 2015)
02-09-2007 06:26 PM
snowblind7x
07-24-2006 11:26 PM
1INTEGRA
06-04-2005 09:52 PM
Blazin Civic
55
07-11-2004 07:01 PM
vpforeva
02-21-2002 01:13 PM
Quick Reply: Castrol EDGE?
