hard shifting
Old 07-09-2008, 06:55 PM
georgelimas's Avatar
Default hard shifting
i have a 1990 accord, 2 door automatic that is shifting very hard threw out driving at times it shifts fine at times not. do you all think that if i get the tranny filter replaced that will fix the problem?also on this car when i give the car gas it has no pick up at take off,but when it gets going it will run great,dont get me wrong if i stomp on the pedal it will go but i dont like to do that.the car is free of any oil leaks,overheating etc. etc. any and all feed back will be used.thanks alot
Old 07-09-2008, 08:32 PM
The-Kid's Avatar
Default Re: hard shifting (georgelimas)
For the tranny, use Honda ATF-Z1 for the fluid. I used to have harsh shifting with my 96, but after the change, shifts soooo nice. <3 it. =P
For performance, there's lots of things. Maintenance is one of them. Have you done any on the car? Tune-up?
Change your spark plug, wires, air filter, clean out the EGR ports, clean your TB. Look in the Accord FAQ for more info on maintenance.
Old 07-09-2008, 09:03 PM
lazyguy13's Avatar
its an auto
they are not good for driving fast no matter how u slice it
Old 07-10-2008, 08:51 AM
Default Re: hard shifting (lazyguy13)
yeah when i bought the car thats the first thing that i did is give it a real good tune up,plugs,wires,cap,rotor,ignition coil,all filters except the tranny!this was all about a month ago.now im going to try the fluid you refered me too.thanks alot.by the waY is it compicated to change the tranny filter?
Old 07-10-2008, 09:58 AM
The-Kid's Avatar
I think changing the tranny filter requires you to remove the tranny from the engine. I will say that is complicated. I don't know about the tranny used in the 90's Accord but there is no cover or pan. It's one complete housing.
Old 07-13-2008, 05:00 PM
where do i purchase atf-z1?i checked oriley and nothing.they act as if they never heard of such.
Old 07-13-2008, 05:39 PM
YeuEmMaiMai's Avatar
also you can add a can of lubeguard for imports (red cap) if the unit has hier milage......
Old 07-13-2008, 07:20 PM
95-Accord-EX's Avatar
Default Re: (YeuEmMaiMai)
i think the only place u can buy atf-z1 is at honda... dont hold me to it tho, but i'm pretty sure thats the only place
Old 07-13-2008, 09:10 PM
The-Kid's Avatar
Default Re: (95-Accord-EX)
Yea I forgot to mention that. Sorry. Its a Honda product. I think its around high 6 to around 7 dollars a quart. You can safely get 3 quarts? Worth the money.
Old 07-22-2008, 12:28 AM
addicted2blue's Avatar
i would suggest draining the trans fluid and refill also, i done this when i first got it and it did help
norton54
01-20-2007 03:46 AM
Dad1999
06-21-2006 05:55 AM
sony224422
01-12-2006 04:14 PM
D-X-Factor
11-16-2005 09:33 AM
wopspice
02-17-2003 06:16 AM
Quick Reply: hard shifting
