Car shakes at speed over 60 mph.. - Honda-Tech
Old 03-25-2015, 12:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 04-05-2006, 09:37 AM   #1
chodu's Avatar
Default Car shakes at speed over 60 mph..
Car shakes bad at speed over 60 mph.I just changed the front engine mount thinking It will stop all the vibration but no...It is sumthing else...Help me..
Can Sway Bar Brushings be the cause because right side brushings are bad...
Can It be wheel alignment...
At High Speeds the passenger seat shakes bad also.
Another question, How often should I change my transmission fluid and can bad transmission fluid cause the engine to heat up..
Its a 95 Accord EX 4 dr..
chodu is offline   Reply With Quote
Old 04-05-2006, 10:03 AM   #2
Durkhanus's Avatar
Default Re: Car shakes at speed over 60 mph.. (chodu)
A likely problem is that your tires are unbalanced. Do you notice some vibration at lower speeds? Does your your steering wheel seem to shake a bit when driving at lower speeds? Can you see your steering wheel shaking back and forth when you let it go while driving?
If so, you should take your car in to a tire shop and have them check the balance of your tires.
Durkhanus is offline   Reply With Quote
Old 04-05-2006, 10:05 AM   #3
In a Junkyard near you.
Ross 2.0's Avatar
First I would have the tires balanced and checked for uneven wear and damage.
Then I would have an alignment done.
Bad sway bar bushings will cause a rattle in cornering and extra body roll.
Transmission fluid should be changed every 30K miles or less. Also bad fluid won't make your engine overheat. How hot is it getting and when does it heat up?
Ross 2.0 is offline   Reply With Quote
Old 04-05-2006, 10:13 AM   #4
chodu's Avatar
Ok I will get my tires balance...
Sometimes car use to overheat when temp. was hot outside and usually happens during street road driving Not during Highways.. As soon as car moves temp. comes back down..
thanx mate
chodu
Old 04-05-2006, 10:38 AM   #5
Ross 2.0's Avatar
with your ignition turned on (engine not running) turn the a/c on and see if both fans are running.
Old 04-05-2006, 11:13 AM   #6
jack the front of the car up and then try to move the tire left to right on each front wheel. IF you can you got bad tie rod end if you can move itup and down. you got ball joint problems.
YeuEmMaiMai is offline   Reply With Quote
Old 04-06-2006, 02:08 PM   #7
Xx91AccordxX's Avatar
My 4th gen would do the same thing. Like the others said, check for uneven tire wear and get them balanced. It also could be a warped brake rotor or a frozen brake caliper... does the car still shake while braking or pull hard to one side? Mine did and it turned out the passenger side front brake caliper had frozen on the rotor. Anyway, hope that helps a little... good luck!
Xx91AccordxX is offline   Reply With Quote
Old 04-07-2006, 05:03 PM   #8
HONCORD's Avatar
Default Re: Car shakes at speed over 60 mph.. (Xx91AccordxX)
All answers up above are right.
MooGoCow3 good shot with a 30k trans flush service, 99% of the people dont even know there is a fluid in there, lol.
I worked on bunch of 90-93 Accords and usually, the upper ball joint goes bad on them.
Tie rods? Havent seen one yet (those fkrs are boolet proof).
You said that pass. seat is shaking. Check your axle.
Warped rotor wont cause vibration at high speed, unless you pressing the brake. Then your whole car will shake, like crazy.
Check tires balance first though. Check if tires are cupped (that'll do the shake), thats your struts doing the damage.
Let me know
HONCORD is offline   Reply With Quote
Old 04-17-2006, 12:51 PM   #9
chodu's Avatar
Default Re: Car shakes at speed over 60 mph.. (HONCORD)
Thank a lot guys...
My rear driver tire was stripped from inside...That was causing all the vibrations.. I changed it ..Now car runs fine... Although I do have cupped(inside and outside waer on tire) front tires..Later fellas.. thank again
Shake at Higher Speeds and Braking bank2me Acura Integra 12 08-06-2011 03:19 PM
Another engine mount question.... Petah Honda Civic (2001 - 2005) 4 11-22-2010 07:40 PM
Vibration/Shake after 60mph. '95 BA8 Honda Accord (1990 - 2002) 7 08-15-2008 07:26 AM
steering wheel shakes at high speed EJ1 guy in LBC Honda Civic / Del Sol (1992 - 2000) 7 02-18-2008 12:32 PM
Blown shock? xxxmikenicexxx Acura Integra 6 03-11-2004 12:44 PM
Tags
60, 60mph, 95, accord, alignment, car, driving, honda, mph, shakes, shaking, speed, starts, tire, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
