Rear Disc conversion
Old 10-21-2019, 08:05 AM
ekgm6's Avatar
Icon5 Rear Disc conversion
hey guys i have a 1990 Accord and i was wondering if its possible to do a conversion from the drum brakes to disk, and if so which cars are good donor cars ?
Old 10-21-2019, 12:46 PM
Premium Member
Aradin's Avatar
Default Re: Rear Disc conversion
Best bet would be to find a 90-93 Accord with rear discs and pull the rear subframe, trailing arms, brakes, e-brake cables, hoses, etc and swap it to yours.
I believe there is some difference between the drum and disc prop valves also. The drum prop valve has less rear bias than the disc prop valve, so your braking performance will actually be worse unless you swap in the correct prop valve.
boostedbatch
10-03-2010 01:31 PM
95blkcivic
14
02-19-2010 10:04 AM
Corruption
06-13-2006 12:22 PM
greebler
01-09-2004 11:24 AM
Quick Reply: Rear Disc conversion
