car dies when hitting brakes and idle surges up and down HELP!!!
Old 12-18-2007, 07:08 PM
supertuner91ef's Avatar
Default car dies when hitting brakes and idle surges up and down HELP!!!
WORKING ON A 1990 HONDA ACCORD, IT DIES WHEN I PRESS THE BRAKES AND THE IDLE SURGES. WHAT COULD BE CAUSING THIS??? IF ANYONE CAN HELP OR GIVE ME AN IDEA I'D APPRECIATE IT.
Old 12-18-2007, 07:25 PM
Default Re: car dies when hitting brakes and idle surges up and down HELP!!! (supertuner91ef)
PLEASE DOES ANYONE HAVE ANY IDEAS?
Old 12-18-2007, 10:21 PM
radiuslight's Avatar
Ive had that problem before
once it was because my coolant level was low
then once again when my idle was set too high
start there check it out
Old 12-20-2007, 01:10 PM
Default Re: car dies when hitting brakes and idle surges up and down HELP!!! (radiuslight)
tired that what else could i try
Old 12-20-2007, 01:24 PM
two_brothers_racing's Avatar
there is something wrong with your brake booster when you hit the brakes the power that the booster takes is messing with the idle
Old 12-20-2007, 05:40 PM
hondadude's Avatar
The brake booster uses a large amount of the available intake manifold vacum.
I'd start by looking around for broken vacum lines, or vacum leaks.
Also check the IACV, idle should drop a couple hundred RPM if you unplug it with the engine idling.
muddmonky
11
01-24-2013 05:34 AM
wasabijim
12-27-2010 03:00 PM
seeodywhy
07-19-2009 11:30 AM
u_gnit
08-11-2006 09:21 AM
StupidSlowRSX
03-17-2004 04:38 PM
Quick Reply: car dies when hitting brakes and idle surges up and down HELP!!!
