Car chokes when starting any suggestions?
recently the car has a bad start,
when i turn the key, it chokes for a few seconds before it starts,,,
back then it use to start on the first turn,
anyone know what might be wrong??
or what i might need to change or check up on?
thanks..
thanks..
Re: Car chokes when starting any suggestions? (Mike813)
Could be a few things...
1. could be that ur car isn't getting enough air?
2. could be that ur car isn't getting enough gas?
3. could be that ur car has bad spark plugs?
4. could be... there is more, but check these out first...
Re: Car chokes when starting any suggestions? (dclub01)
1...i checked my throttle body and cleaned it its doing ok
2...gas part i dont know how to check that? do i need to change the filter u think?
3...spark plugs was just changed less than 2k miles.
4...?
it only does this once in a blue moon, not always...so u think it might be my gas filter? i have never changed that before since i got the car at 57k miles.. im way over 100k now...
thanks for the reply..
4...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 »</TD></TR><TR><TD CLASS="quote">...spark plugs was just changed less than 2k miles...</TD></TR></TABLE>
How about distributor cap & rotor, & spark plug wires? How old are they?
Re: Car chokes when starting any suggestions? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">
How about distributor cap & rotor, & spark plug wires? How old are they?</TD></TR></TABLE>
i changed them the same time i changed my spark plugs, had a tune up,
so the only thing i think that it might be is the gas filter?? i think...
fuel filter on 94+ is a bitch to change. Many ppl just don't want to do it unless the master brake cylinder is out. Try changing that if your over 80k miles...(technically the change interval is 30k)
Re: Car chokes when starting any suggestions? (RotaryBzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzz »</TD></TR><TR><TD CLASS="quote">fuel filter on 94+ is a bitch to change. Many ppl just don't want to do it unless the master brake cylinder is out. Try changing that if your over 80k miles...(technically the change interval is 30k)</TD></TR></TABLE>
well lets say, ever since i got the car i never changed the filter, nor do i know if the last owner did... so im assuming its been damn long since the fuel filters been changed ,,, how much you think local shops would do this for??
editingideas
07-25-2018 11:33 PM
leekor12
04-20-2007 08:45 PM
greddy13
04-10-2006 06:54 PM
