Can't get front wheel off!!?? - Honda-Tech
Old 02-27-2011, 01:25 PM   #1
Default Can't get front wheel off!!??
Hi Accord Gurus,
I just bought a used 95 Accord Coupe LX and have started to dive in and do routine maintenance. Just ran into a problem getting the front wheel off to rotate tire with back one. Got all the lug nuts off but wheel won't budge. Also, the inner area of the front rims looks different than rear. Is there something simple I am overlooking?
Thx.
mem94043 is offline   Reply With Quote
Old 02-27-2011, 01:35 PM   #2
Default Re: Can't get front wheel off!!??
lug nuts are off,,,kick the bottom of the tire.
poorman212 is offline   Reply With Quote
Old 02-27-2011, 01:52 PM   #3
19Accord97's Avatar
My front passenger tire usually gets stuck like that. I grab a 2x4, put it against the inside of the tire on the bottom and hit it with a hammer/sledgehammer.
19Accord97 is offline   Reply With Quote
Old 02-27-2011, 01:54 PM   #4
MoguMagic's Avatar
Rubber mallet on the tyre listening to drumstep XD....
But seriously, just try to free it from the hub with some gentle but firm smack your b!1ch up
MoguMagic is offline   Reply With Quote
Old 02-27-2011, 02:14 PM   #5
Put the lug nuts back on loosely about a 1/16th of an inch from the wheel lug seat.
In your driveway start the car backing up a few feet brake hard put in drive roll a few feet brake hard again. Do this a few times and the wheel will break free of the hub.
When done smear anti-seize on the hub so this won't happening again.
DO NOT KICK the wheel from under the car unless the ER sounds like a great place to spend your money.
Nicefeet is offline   Reply With Quote
Old 02-27-2011, 02:52 PM   #6
soon2bdropped's Avatar
put a lugnut back on and hit the inner side of the rim with a rubber mallet. try not to rock the car to much..
soon2bdropped is offline   Reply With Quote
Old 02-27-2011, 04:11 PM   #7
or get a gear puller lol happened with my golf i had. the hub was warped on the inside and it was stuck stuck i spent 2 hours with a ruber mallet and a 2x4 then decided to get a gear puller haha
95acrd is offline   Reply With Quote
Old 02-27-2011, 04:51 PM   #8
MoguMagic's Avatar
Did you listen to drumstep ? Won't work otherwise with the rubber mallet, they are fussy
Anyway.... Sure there way a thread somewhere recently with a pic of how to do it. i'll go look.
Old 02-27-2011, 07:01 PM   #9
are you guys serious right now? i have never encountered a tire that didnt instantly pop right off. am i just really lucky? my only guess is that something is rusted together
specialone70 is offline   Reply With Quote
Old 02-27-2011, 07:07 PM   #10
phootbag's Avatar
The wheel fits over the hub with very little extra room. This is the self-centering mechanism and is good to ensure proper centering, obviously, and proper torque of the lug nuts. The slightest bit of corrosion can make the wheel difficult to remove.
As was stated, use an object, preferably inanimate, and beat the **** out of the wheel. It will fall off.
Additionally, when it is removed, clean and lubricate the surfaces of the hub and wheel. This will prevent the problem in the future.
phootbag is offline   Reply With Quote
Old 02-27-2011, 10:31 PM   #11
MM Gruppe B
MAD_MIKE's Avatar
Oh man, nobody mentioned using a sawzall? Where is that thread?
MAD_MIKE is offline   Reply With Quote
Old 02-27-2011, 10:33 PM   #12
just hit it with ur purse lol na just use the mallet, u need to buff off the corrosion of that hub
Got Vtec507 is offline   Reply With Quote
Old 02-27-2011, 10:44 PM   #13
hit the rim with a rubber mallet
mikeyreolegio is offline   Reply With Quote
Old 03-01-2011, 05:20 PM   #14
Nicefeet thanks for a brilliantly SIMPLE idea.
Before posting the other day I was smackin the you-know-what outta the tire with my mini sledge. Even drenched the lugs with PB Blaster. Sucker would not come loose. Followed your suggestion: I loosened the lug nuts, then finger-tightened, then loosened one turn (about 1/16th"). Got in the car and drove back and forward in driveway hitting the brakes hard. Jacked the car back up and gave one good kick with my heel on the tire and she cracked loose. Made sure to put a thin layer of Permatex Anti-Sieze on back on rim to avoid this stupid problem in the future.
THANKS AGAIN NICEFEET.
How to set TDC? 96 Accord, help Jeul Honda Accord (1990 - 2002) 9 01-24-2012 10:44 AM
how do you remove the front wheel studs on a honda accord ANGEL4PEACE777 Honda Accord (1990 - 2002) 1 08-14-2007 04:45 AM
Wheels rusted on Hub funz0rzies Wheel and Tire 3 04-12-2007 05:28 PM
93 Accord brakes and rotors Joetravelall Honda Accord (1990 - 2002) 4 02-20-2007 04:25 AM
Accord front brake swap... what else fits? nub.96ek Honda Accord (1990 - 2002) 2 09-17-2005 11:15 AM
Tags
05, 1989, 95, accord, acura, civic, front, honda, hub, interested, off, prelude, stuck, tire, tsx, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
