Can anyone decipher this alignment sheet for me?????
I got my 1991 accord ex aligned and I have replaced everything in the front suspension other than the lower control bushings and struts... Well the wheel still vibrates like crazy past 60mph... Check this sheet out and see if you can tell if anything is wrong by looking at it.. Thanks
Front Left Front Right
Actual Before Specified Range Actual Before Specified Range
-0.5 -0.6 -1.0 - 1.0 Camber -0.5 -0.6 -1.0 - 1.0
2.4 2.4 2.0 - 4.0 Caster (Bad)1.4 1.4 2.0 - 4.0
-0.03 0.36 -0.12 - 0.12 Toe -0.01 1.43 -0.12 - 0.12
6.9 6.9 SAI 7.2 7.2
6.4 6.4 Included Angle 6.6 6.6
Front Actual Before Range
Cross Camber 0.0 0.0
Cross Caster 1.0 1.0
Cross SAI -0.2 -0.2
TOtal TOE -0.04 1.80 -0.24 - 0.24
6.9 6.9 SAI 7.2 7.2
Cross SAI -0.2 -0.2
Re: Can anyone decipher this alignment sheet for me????? (tedog)
What I am really wondering is why the right tire caster in 1.4 and they could not adjust? How can I fix this?
Most likely not an alignment problem. Either out of round rims or off balance tires or damaged axels..
Blamm!!
04-07-2008 04:34 AM
TEG98
04-06-2003 08:33 AM
Chris
06-06-2002 01:35 PM
