Can a 2000 integra...
Stock cd player/deck be installed into a 95 accord 4 door lx.
And what kind of things do i need, just the harness or?
Thanx for the help guys.
Re: Can a 2000 integra... (supperfly17)
it will not be a plug and play, honda changed their harness system at 98 and at 06
you'll need the harness from the cd player, and you need a color code for your year of accord.
30 minute job if you solder everything
Re: Can a 2000 integra... (iam7head)
ok so pretty much the hardest part is connecting the wires right, even though there is a tape deck in the accord now, as long as i connect the right wires to the cd player deck from the integra it should work right?
easier way...go to junk yard and get harness for the integra then get harness for accord just like if you were doing a aftermarket radio.
I thought all honda vehicles 98 and up had a different harness also, so when I wired up my friends headunit for his 2000 integra gs with the 98+ harness and pulled out his deck I found that it was the same harness as my 93 accord.
Also in my other friend's 2000 gs-r it has the same harness as my accord and I used his headunit for awhile until I went aftermarket.
Re: (Black Ex Coupe)
Worst case senario youre gonna have to cut and match wires. Right speaker to right speaker, power to power, left speaker to left speaker... etc. Easy stuff should take about an hour for a beginner.
95ejjj
11-26-2005 12:48 PM
