Camber kit front? rear? or both?
I heard some people said most of the 90-97 Accord doesn't need camber kit for rear, but only front camber kit is enough. Is that true? and which brand is good?
Thanks.
Thanks.
Re: Camber kit front? rear? or both? (brian2903)
You could probably get away with just shimming it to the correct alignment settings, but if you want to be sure I would grab a kit. Don't forget though, you will need a front camber kit and a rear upper cross bar. Check out http://www.spcperformance.com/....html
Re: Camber kit front? rear? or both? (RastaGt1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RastaGt1 »</TD></TR><TR><TD CLASS="quote">You could probably get away with just shimming it to the correct alignment settings, but if you want to be sure I would grab a kit. Don't forget though, you will need a front camber kit and a rear upper cross bar.</TD></TR></TABLE>
That's what I did. Used some washers I had lying around in the garage.
Re: Camber kit front? rear? or both? (aaaallll04)
on 6th gen? i dont think so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaaallll04 »</TD></TR><TR><TD CLASS="quote">haha washers will work just fine, but you will probably only need them in the rear</TD></TR></TABLE>
Re: Camber kit front? rear? or both? (iam7head)
you guys know where you can get front camber kit for cheap?
this is where i get mind front camber kit for 70$, i dun know what the price rite now,,,,,probably increase cuz they realize that there a market for it.
http://www.streamlinemotoring.com
and the rear, like many have said, just use couple washer, but note: when u fix the rear, your car will raise a lil and the gap may increase........(thats what happen to my 97 accord.)
matt94z
19
08-08-2008 06:14 AM
