Camber Help
Old 04-09-2010, 07:42 AM
slvrCD7accord's Avatar
Default Camber Help
I am looking at Eibach front alignment kits and there are a couple options. One is +/- 1.5 degrees and the other +1.5/3.00 degrees. I'm not sure which one to order, so I'll post my alignment specs from a year ago and maybe someone can help. The car is a 96 Honda Accord with about a 1.5" drop.
Front Left
Camber: -1.0
Caster: 2.8
Toe: -0.04
SAI: 7.6
Included Angle: 7.6
Front Right
Camber: -1.5
Caster: 2.3
Toe: 0.04
SAI: 7.7
Included Angle: 6.2
I am curious of which kit to get to adjust my camber. I am aware my car is out of alignment and just want to get it fixed. I have some 16x7 buddy club wheels with 205/55/16's waiting to be installed after this fix. Thanks in advance.
Old 04-09-2010, 10:27 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: Camber Help
What are you not understanding with it?
Are you trying to get 0 camber? If that's the case then obviously the +/- 1.5 degrees would be what you want. Otherwise with the other kit - you'd OVER correct and end up with +.5 degrees of camber on your left wheel.
Keep in mind for the rear just doing the rear washer trick (Accord FAQ) will be more than sufficient and significantly cheaper.
TOO MUCH TORQUE
Suspension & Brakes
11
04-19-2011 10:10 AM
TailZ
Honda Civic (2001 - 2005)
04-29-2008 08:13 PM
Mr Hammond
10-12-2006 03:06 AM
Jeff99Base
10-26-2004 04:49 AM
acatak
04-26-2003 07:13 PM
Quick Reply: Camber Help
