Cam Seal Replacement - Honda-Tech
Old 09-04-2007, 08:37 PM   #1
oem_certified_accord's Avatar
Default Cam Seal Replacement
Searched, and got :
http://www.honda-tech.com/zerothread?id=754591
http://www.honda-tech.com/zerothread?id=653381
i have an oil leak coming from my cam seal, and with that being said every 2 weeks i catch low oil pressure. purpose of this post is to ask about the steps involved in a cam seal job.
if it's not too detailed i'll go ahead and knock it out but if i gotta pull this and disconnect that and hassle myself i'll just keep buyin oil until my new motor comes in.
let me know
.Thanks in Advance
oem_certified_accord is offline   Reply With Quote
Old 09-04-2007, 09:45 PM   #2
It Wasn't Me!
someone else's Avatar
Default Re: Cam Seal Replacement (oem_certified_accord)
If it's leaking around a quart + a week you need to do the timing belt too. That belt has to be oil soaked and oil soaked belts like to break. Do the belt and have the crank and balancer shaft seals done as well. Water pump too if it's been awhile.
someone else is offline   Reply With Quote
Old 09-05-2007, 04:25 AM   #3
H-T Order of Merit
TouringAccord's Avatar
you pretty much have to go through all the steps of a timing belt replacement.
Like stated above, those belts are soaked in oil by now and it would be best to replace the belts anyway.
to remove the seal, take a scratch awl and place it on the face of the seal and tap it with a hammer to poke it through the face of the seal. Then just pry it out. Make sure you dont scratch the camshaft or the head. Put the new seal in place, put a large socket over it and tap the socket with the hammer until the seal is in place.
I have pictures from when I did this on a Civic, but it's the same procedure if you'd like to see.
TouringAccord is offline   Reply With Quote
Old 09-05-2007, 09:52 AM   #4
Default Re: Cam Seal Replacement (TouringAccord)
yes pics would help a lot TA, it's not so much leaking onto any of the belts it just drips out and trickles down onto the pan.
Old 09-05-2007, 10:29 AM   #5
H-T Order of Merit
ok, here is basically how it'll look.
step 1: poke the scratch awl through the face of the seal and pry it out
step 2: position the new seal in place
step 3: using a large socket tap the new seal into place
step 4: finished
in step 1 I've already pried the seal out but you get the idea.
hondadude also posted pictures on how he removes those seals. I believe you can find a link to it in the FAQ.
Old 09-05-2007, 10:41 AM   #6
good to go, you got any info on my accord to prelude cluster swap as well?
Old 09-05-2007, 11:06 AM   #7
H-T Order of Merit
edit:
NVM, I guess I hadn't checked it in a while, was out of town last weekend. let me re-read it.
Old 09-05-2007, 11:48 AM   #8
SHAME ON YOU REBECCA!
kidcool1977's Avatar
step 4: finished
TouringAccord
in step 1 you said to poke the scratch awl through the face of the seal and pry it out, What's a scratch awl, don't wanna seem dumb.
kidcool1977 is offline   Reply With Quote
Old 09-05-2007, 12:03 PM   #9
H-T Order of Merit
Default Re: Cam Seal Replacement (kidcool1977)
thats what it's called at Sears. It just a straight piece metal with a sharp point at the end. Sorta like an ice pick I guess.
If you go into Sears and go to the screw driver section you should find them there.
Old 09-05-2007, 04:32 PM   #10
thanks for the input, if it wasn't for this post i would of never known how to get a seal out. Does the same method work for the crank seal?
Traction Bars and their Benefits for Road Racing/Autocross Adam. Road Racing / Autocross & Time Attack 7 05-26-2005 06:51 AM
FS: PARTING OUT MY CAR; B18c ITR TRANNY, HEAD, misc ITR parts 96 ITR conversion, GAB, & ITR slammed_93_hatch For Sale 334 03-02-2005 06:14 AM
SKUNK2 stage 1 one cams FS milo For Sale 6 05-18-2004 10:56 AM
Check Engine Light and Code P0133 ramz7887 Honda Civic / Del Sol (1992 - 2000) 3 07-25-2003 02:29 PM
JUN3 cams please look ASAP Pinhead Acura Integra Type-R 6 03-06-2002 05:21 PM
Tags
1994, 2002, accord, awl, cam, camshaft, civic, crankshaft, honda, leak, pick, prelude, remove, replace, replacement, seal, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
