A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder
Old 09-28-2013, 11:33 AM
PredatorCoder's Avatar
Default A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder
What the title says: A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder. For some reason, my AllData subscription doesn't have a diagram for the evaporator overhaul that includes torque specs. Can anyone look these up in the factory service manual? There are three different fasteners involved; I need them all...
Old 09-28-2013, 11:06 PM
holmesnmanny's Avatar
Default Re: A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder
strangely my Helms doesn't give expansion valve torque specs but most of the others are between 16 and 23 so just go 23 and you'll be fine.
Old 09-29-2013, 08:00 AM
Thanks. I guess that explains why AllData didn't have the information either.
Old 09-29-2013, 08:24 AM
An update in case anyone else comes across this: it should be obvious, but don't torque every single fastener for the TXV valve to 23 ft-lb.... or you'll be sorry... the three different fasteners vary in size: 14 mm, 19 mm, and a larger one. These are the torque values I'll attempt:
* Larger one: Close to 23 ft-lb but not quite is probably appropriate for this one; the suction line to evaporator fastener is even bigger than this one and is specified for 23 ft-lb.
* 19 mm: The receiver line to evaporator fastener is also 19 mm, and specified to 9.4 ft-lb.
* 14 mm: Who knows? Maybe a little less than 9.4 ft-lb, but no less than 7.2 ft-lb, which is the spec for the 10 mm fasteners.
hagsmich
01-25-2018 07:29 PM
456eec
01-03-2014 07:47 PM
crxguy406
04-06-2013 11:23 AM
94integrals
07-02-2004 11:28 AM
Aquafina
06-13-2004 10:42 AM
Quick Reply: A/C expansion valve torque specs for 1998 Honda Accord LX 4 cylinder
