Broken camshaft? - Honda-Tech
Broken camshaft?
Old 10-23-2004, 04:17 PM   #1
DiGG3r's Avatar
Default Broken camshaft?
I was driving and the motor just quit (0 RPM), when I tried to restart, the car turned but wouldn't start. I went through the usual checking to see what happened (fuel pump & line, timing belt, fuses, dizzy, etc.) The timing belt was fine, but the dizzy wasn't turning, I guessed it was bad. Then I took off the valve cover to see if it was anything else, When I had the car try to start I looked at the camshaft, it was only turning over cylinder 1, not anywhere else. I have a stock 94 accord 2.2L, with no mods. Does this mean my camshaft broke?? Please HELP!
DiGG3r is offline   Reply With Quote
Old 10-23-2004, 05:35 PM   #2
StimpyBoy's Avatar
Default Re: Broken camshaft? (DiGG3r)
From what you've described, you pretty much nailed your own problem. You had someone else try to start the engine while you watched, right?
I've never heard of a camshaft snapping like that in a stock Accord engine, but I guess there's a first time for everything
BTW, if you did get it right, then you probably have valve/piston damage as well as I'm sure you're aware. If you're sure it's the camshaft, you're going to have to pull the head now and look for damage for sure. Sorry.
StimpyBoy is offline   Reply With Quote
Old 10-23-2004, 05:40 PM   #3
Section.9.Auto's Avatar
Default Re: Broken camshaft? (StimpyBoy)
It can happen i have seen it a few times on hondas. Usually only on the older ones like mid 80s. When they go it usually destroys the whole head, because the cam bents the line bore that the shaft runs down. Can be re-machined , but cheaper to get a whole reman head and put it on. That also gets rid of the valves that are most likely bent.
Section.9.Auto is offline   Reply With Quote
Old 10-23-2004, 06:40 PM   #4
DiGG3r's Avatar
Default Re: Broken camshaft? (Section.9.Auto)
So do I have to remachine my head? What would cause the cam to break like that to begin with? It's all stock and I don't race, so what would cause the cam to break like that??
Old 10-23-2004, 06:45 PM   #5
bill-71SS's Avatar
I have seen that happen a lot when there was an oil problem and the cam seizes in the head and snaps.
bill-71SS is offline   Reply With Quote
Old 10-23-2004, 07:17 PM   #6
DiGG3r's Avatar
Default Re: Broken camshaft? (bill-71SS)
well my oil light did come on about a day or two before the cam broke, I checked my oil and it was full. This repair is going to cost me quite a bit.
Old 10-23-2004, 08:14 PM   #7
New User
Nick H's Avatar
you most likely had an oil passage clogged, or something along those lines...if your cam broke, then you may be dealing with more than just machining...you most likely will need a new head, or remachined head, along with most other parts of your valve train...they go on ebay for cheap though...other causes of cams breaking are hitting the rev limiter or over revving the engine to where the cam was spinning too fast for its own strength...can you physically see a break/crack in the cam? is the entire thing spinning?
Nick H is offline   Reply With Quote
Old 10-23-2004, 08:26 PM   #8
DiGG3r's Avatar
Default Re: Broken camshaft? (Nick H)
The cam only spins up to the first cam holder (which I'm guessing where the break is, and I can't see the actual break), the rest of the cam doesn't move at all.
BTW, thanks for all the advice from those who responded.
Old 10-23-2004, 08:36 PM   #9
Shinbo's Avatar
I think this is a glorious opportunity for a new car
Shinbo is offline   Reply With Quote
Somewhat noob question about interference and a timing belt failure civicseth Honda Civic / Del Sol (1992 - 2000) 11 08-05-2009 07:15 PM
camshaft mikensu1 Honda Civic / Del Sol (1992 - 2000) 4 10-19-2007 04:25 PM
timing belt either too tight or too loose 89sparks All Motor / Naturally Aspirated 3 08-31-2007 07:27 PM
At TDC, UP arrows on cam gears are not pointing up and not aligned. Please HELP! redg2ls Acura Integra 7 01-15-2007 11:08 AM
just got my engine all back together and im having trouble with ignition timing lsvtec101 Forced Induction 7 03-21-2003 04:31 PM
Tags
accord, broke, broken, cam, cams, camshaft, civic, cost, crack, fixing, honda, motoer, snapped, stock, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
