14mm hub/rotor assembly bolts 1996 Accord
Old 06-26-2015, 03:07 PM
ksbsr6gn's Avatar
Default 14mm hub/rotor assembly bolts 1996 Accord
New to the forum. Hello Everyone. I have a 1996 Accord. I'm trying to find a couple of replacement bolts for the front rotors/hub assembly (there are four of them) and can't seem to get any help from the auto parts stores. They are the 14mm bolts of the hub assembly that fasten the hub to the rotor. I bought new rotors and brake pads and planned on replacing everything, but I couldn't get two of those four bolts out. Needless to say I completely ruined a couple of them and need replacements. Does anyone know the part number or specs or possibly where I can get a couple of these bolts? Like I said: they are 14mm hex head bolts and there are a total of four on each front hub/rotor. I thought an auto parts place would have the info, but I have called several and they don't seem to know what I'm talking about. The car is a 1996 Honda Accord. It's the very basic model....2.2 four cylinder engine. And again....the bolts are NOT the screw head looking countersink type. They are the 14mm hex head bolts. Can anyone help? Thanks. Chuck
Old 06-26-2015, 03:52 PM
holmesnmanny's Avatar
Default Re: 14mm hub/rotor assembly bolts 1996 Accord
Head to the nearest junkyard
Old 06-26-2015, 04:40 PM
djkurious's Avatar
Old 06-26-2015, 07:24 PM
scubacamper's Avatar
If it's like my local jy's they're low on accords - I would suggest finding the part no. On a honda parts Website like majestichonda.com and shopping the Internet by the part number...
Old 06-27-2015, 05:47 AM
djkurious's Avatar
http://www.hondapartsnow.com/diagrams/large/front-brake-akebono-2148506.png
#22?
Old 06-27-2015, 06:58 AM
tim73's Avatar
Take one of the bolts with you to the auto parts store. They sell bolts, in a rotating end cap display. Just match the thread pitch and the bolt diameter. Easiest way is to find a nut that fits your bolt...then buy a bolt that the same nut fits. Get the same or close to the same length.
Old 06-28-2015, 03:58 PM
RTFM
v4lu3s's Avatar
parts stores suck for bolts, especially metric. i would get new ones from honda.
Old 06-29-2015, 12:43 AM
MM Gruppe B
MAD_MIKE's Avatar
90114-SM4-000
Bolt, Flange (10X20)
~$2 each from the dealer.
Old 07-01-2015, 03:07 PM
Lost Again's Avatar
You need to find a better parts store to shop at.
Old 03-24-2018, 05:34 PM
Jesso37's Avatar
Hub/Rotor bolts are 10x1.25x20.
Got them at a basic hardware store.
ddb0825
05-07-2017 08:13 PM
SnoopyMan
12-06-2012 07:44 AM
hs545
09-08-2010 01:34 AM
dbbyleo
09-21-2008 12:49 PM
hob
03-07-2008 05:45 AM
Quick Reply: 14mm hub/rotor assembly bolts 1996 Accord
