Brake Lamp Light
Old 03-18-2011, 06:25 PM
curtie94's Avatar
Default Brake Lamp Light
On my 1991 Honda Accord my brake lamp warning light comes on periodicaly. This is the light that says if there is a brake light out. All of my lights work. I was just wondering, what would happen if I just disconnected the switch. Would the light stop coming on?
Old 03-19-2011, 02:42 AM
phootbag's Avatar
Default Re: Brake Lamp Light
I've seen faulty check circuit relays in the trunk cause this. Sometimes those relays get corroded connectors because the relay is in the trunk and gets wet occasionally. I've also found an overheated solder joint in the check circuit in the gauge cluster before. I melted the solder with an iron to fix the connection.
You need an electrical schematic and a multimeter to diagnose the problem.
Old 03-19-2011, 08:26 AM
AndyD's Avatar
I have the same problem. Some of my bulb connectors are corrodid. I found that you can buy the tail light harnesses from hondaautomotiveparts.com for $15 each. I might give that a try.
Old 03-24-2012, 10:12 AM
Del Green's Avatar
i had same problem, replaced all bulbs, same thing, then i started disonnecting connectors on tail and trunk lights, found corrosion in connectors. cleaned them up and light went off.
Tech-Nics
11-01-2022 07:06 PM
misterix
07-06-2009 07:31 PM
raffydogg
Lighting
03-23-2008 11:53 PM
raffydogg
03-21-2008 06:32 PM
boris2286
05-05-2005 02:54 PM
Quick Reply: Brake Lamp Light
