Brake Lamp indicator..what does it mean - Honda-Tech
Old 08-15-2011, 11:17 AM   #1
dlewis2583's Avatar
Default Brake Lamp indicator..what does it mean
sup HT, well the other day my brake lamp indicator came on and its never come on my 97 accord. what does it mean? how can i fix it? How much would it cost? thanks!
Name:  2011-08-13 21.01.00.jpg
dlewis2583 is offline   Reply With Quote
Old 08-15-2011, 11:39 AM   #2
Default Re: Brake Lamp indicator..what does it mean
It means replace one of your lights more than likely
deuce2.2 is offline   Reply With Quote
Old 08-15-2011, 12:55 PM   #3
it can mean various things, bulb need to b replaced, sometime the replacement bulb uses a lower voltage so the brake lamp lite comes up, sometimes its a faulty brakin wire leading to the bulb
mapoconcepts is offline   Reply With Quote
Old 08-15-2011, 01:30 PM   #4
dlewis2583's Avatar
I checked my bulb and its not blown or anything...
Old 08-15-2011, 02:37 PM   #5
cdaiscool's Avatar
For my old Accord, it meant the brake fluid was low. Go check it and report back.
cdaiscool is offline   Reply With Quote
Old 08-15-2011, 02:42 PM   #6
ivey_usmc's Avatar
Quote:
X2
ivey_usmc is offline   Reply With Quote
Old 08-15-2011, 03:03 PM   #7
Quote:
Attachment 225989
It's just a light bulb. Don't forget to check the three of them.Two of them are double filament #7443 and the other high mounted"cyclops" is a single filament.It could be just a bad contact in one of them.
exb18c1 is offline   Reply With Quote
Old 08-15-2011, 03:43 PM   #8
dlewis2583's Avatar
Brake fluid is full...just dark! Going 2 check the bulbs now...
Old 08-15-2011, 05:31 PM   #9
dlewis2583's Avatar
Quote:
So it was 2 of the 3...how the hell do i get to the high mounted brake light?
Old 08-15-2011, 07:02 PM   #10
From the trunk.
[DIY] Honda Civic 92-95 "OEM" Rear Fog Lamp Retrofit Install Guide deschlong Honda Civic / Del Sol (1992 - 2000) 47 09-08-2015 08:07 PM
94 Accord EX Intermittent 'Brake Lamp" Indicator Light moundsostuf Honda Accord (1990 - 2002) 11 02-28-2015 10:12 PM
1993 Accord brake lamps staying on when car is off LittlesilverEF Honda Accord (1990 - 2002) 2 01-24-2009 02:07 PM
1998 Civic: Voltage Signal from Transmission Sensor Out of Range Rose of Cairo Honda Civic / Del Sol (1992 - 2000) 2 11-18-2008 08:23 PM
'88 Accord LXi/Brake Lamp Indicator RAYThOM Honda Accord (1990 - 2002) 3 07-28-2006 10:31 AM
Tags
2000, 2002, 2005, 94, accord, brake, break, breaklamp, honda, indicator, lamp, lights, odyssey, on, parking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
