brake caliper slide pin stuck! - Honda-Tech
Old 06-25-2006, 12:40 PM   #1
vietxdragon's Avatar
Default brake caliper slide pin stuck!
ahh so im trying to remove the brake caliper slide pin on my rear brake calipers on a 92 accord sedan ex since they were seized up on both sides, how would i go about getting those pins out ? its the brake caliper slide pins if im correct
vietxdragon is offline   Reply With Quote
Old 06-25-2006, 01:03 PM   #2
hondadude's Avatar
Default Re: brake caliper slide pin stuck! (vietxdragon)
remove the dust boot if possible and then use some rust penetrant and keep tapping on the housing while trying to get the pin twisting and turning. If it's is really bad you might drill a small hole into the housing, reseal it with epoxy later, and get some Blaster penetrating fluid in that way.
The problem with really bad corrosion is, after cleaning it all out there might be too much slack around the pin and the setup will wiggle when you step on the brake.
hondadude is offline   Reply With Quote
Old 06-25-2006, 02:08 PM   #3
ok i've tried smacking the housing with a hammer but no budge its in their pretty good> got any other ideas? any another thing i cant get 1 bolt off to remove the caliper bracket. the 14mm bolt, thats in their pretty good too. it seems that the previous owner of the car snapped the other bolt cuz it was a different bolt, lol it was like a 17mm bolt head with 2 washers. I'm getting frustrated help would be nice
Old 06-25-2006, 02:38 PM   #4
Chiovnidca's Avatar
Quote:
I heat the bad ones up with the torch to get em out. You'll need a new boot if you do that.
Chiovnidca is offline   Reply With Quote
Brake Caliper Slide Pins.. kevinmcc2 Honda Civic (2006 - 2015) 6 11-09-2015 12:49 PM
Front brake problem Some quick help required Integra4lyfe069 Acura Integra 8 05-10-2011 08:36 PM
Rear Caliper Slide / Guide Pins phil_lt1 Honda Civic / Del Sol (1992 - 2000) 1 06-24-2009 12:48 PM
brake caliper problem PabloDiablo Honda Civic / Del Sol (1992 - 2000) 7 05-30-2007 07:45 PM
Brake Caliper Slide Pin Maintenence CardDealer Honda Civic / Del Sol (1992 - 2000) 5 08-19-2006 11:02 AM
Tags
accord, acura, blaster, bracket, brake, brakes, caliper, honda, pin, pins, remove, seized, slide, slider, stuck, wd40
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
