HELP MY CAR SOMETIMES IS STUCK IN PARK
Old 06-16-2008, 04:27 PM
hotredheadonabreast's Avatar
Default HELP MY CAR SOMETIMES IS STUCK IN PARK
Sometimes when I crank my car I am not able to put it into drive. When this happens I have also noticed that my brake lights are not working. Sometimes it goes into drive just fine other times I have to keep pusing the brakes. I just bought new brakes and a brake line. Does anyone know what this could be? I am getting ready to travel and don't want to get stranded on the highway.
Modified by hotredheadonabreast at 4:24 AM 6/17/2008
Old 06-16-2008, 04:39 PM
Default Re: HELP MY CAR SOMETIMES IS STUCK IN PARK (hotredheadonabreast)
ok does anyone know where my wire is that goes to the brakes maybe it is loose?
Old 06-16-2008, 06:01 PM
Mr Yamada's Avatar
The brake light switch is located under the dash. You will see a plunger type switch that contacts the brake pedal arm.
Old 06-17-2008, 03:02 AM
BBallz24's Avatar
Sounds like a fusr to me. It's for your reverse lights, will lock car in park. Had it happen to me a couple times. Try replacing it.
Old 06-17-2008, 03:26 AM
Default Re: HELP MY CAR SOMETIMES IS STUCK IN PARK (BBallz24)
Sometimes I have to wait awhile after pressing the brake for me to be able to get it out of park. It is happenng more frequently. Where is this fuse located?
Old 06-17-2008, 08:13 AM
Brad_and_the_acc's Avatar
Before I had my auto to manual swap that happened everynow and then to me aswell. What I did was put my key in the shift lock hole by the shifter and pulled it out of park and put it in neutral and started it from there. I am not sure of the EXACT problem but that it was I did to get it out.
Old 06-17-2008, 11:05 AM
Hharrishonda's Avatar
The best thing i would tell you to do is just convert to 5 speed
Old 06-17-2008, 12:13 PM
Default Re: HELP MY CAR SOMETIMES IS STUCK IN PARK (Hharrishonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hharrishonda &raquo;</TD></TR><TR><TD CLASS="quote">The best thing i would tell you to do is just convert to 5 speed </TD></TR></TABLE>
I will second that!
Old 06-17-2008, 03:08 PM
erk89's Avatar
Default Re: HELP MY CAR SOMETIMES IS STUCK IN PARK (Brad_and_the_acc)
and your horn doesnt work huh? then its probably fuse #19 or 20 under your hood i cant remember exactly which one but its colsest to the front of the car.
Joetxstate
03-04-2020 05:37 AM
93grayeg
19
09-08-2009 07:30 PM
joey8099
06-02-2008 04:04 AM
buddahbert83
12-26-2006 09:19 PM
88crxhfb16
11
07-28-2005 08:07 PM
Quick Reply: HELP MY CAR SOMETIMES IS STUCK IN PARK
