Bleeding the cooling system - Honda-Tech
Old 06-05-2009, 12:19 PM   #1
New User
Default Bleeding the cooling system
When I bleed the cooling system on my 93 accord are these the steps I should follow.
1. fill radiator to top with fluid
2. replace rad cap and start engine
3. open (or totally take out not sure which) bleed screw
4. wait until a steady stream of coolant seeps out of bleed opening
5. tighten screw and fill radiator when cool
Paulie10 is offline   Reply With Quote
Old 06-05-2009, 05:13 PM   #2
Default Re: Bleeding the cooling system
Dont have the car running with the bleeder loose. If the thermostat is closed and the car is cold, air will get sucked in at the bleeder.
92civlude is offline   Reply With Quote
Old 06-05-2009, 05:41 PM   #3
You are also supposed to run the engine with the radiator cap off until the cooling fan comes on at least twice. Makes a lot of mess, but you will see tons of air coming out.
Don't forget to set the heater temp dial to max before you start, too.
nysdriver is offline   Reply With Quote
Old 06-05-2009, 10:37 PM   #4
jonesdesign's Avatar
anyone know if this applies to all 90-93 accord models?
jonesdesign is offline   Reply With Quote
Old 11-08-2009, 05:34 AM   #5
madracer's Avatar
Where is the bleed screw????
madracer is offline   Reply With Quote
Old 11-08-2009, 08:19 AM   #6
redbull-1's Avatar
Quote:
It is usually shown in your owner's manual. But if you don't have it, post the year of the car and model (e.g. 19XX Accord, Civic) or google.
redbull-1 is offline   Reply With Quote
Old 08-11-2010, 10:22 PM   #7
Icon2 Re: Bleeding the cooling system
What is the torque spec for the bleeder screw?
Thanks.
Bad_dude is offline   Reply With Quote
Old 08-11-2010, 10:25 PM   #8
Doesn't need to be tight, you'll know when it's tight enough 'cause it'll stop spewing coolant. When you do bleed, make sure you to turn your heater blower on full blast.
I'm gonna find my service manual and get the right specs.
holmesnmanny is offline   Reply With Quote
Old 08-11-2010, 10:27 PM   #9
7lb-ft dude
Old 08-11-2010, 10:29 PM   #10
I just found the drain bolt for draining the block it's just to the left of the oil filter, 36lb-ft
Old 08-11-2010, 11:03 PM   #11
Quote:
Is it under with the oil filter or on top in the engine bay? And when do you need to drain the block?
Thanks.
Old 08-12-2010, 12:37 AM   #12
Quote:
Thanks.
to the left of it, you would need to if you remove the thermostat housing when doing the intake manifold as we're talking about in that other thread and when taking out the water pump, head off, stuff like that.
cooling system issue h22a2JZGTE Honda Accord (1990 - 2002) 1 02-25-2013 08:13 AM
How to bleed cooling system with no bleed screw Nkietzer Honda Accord (1990 - 2002) 9 08-31-2010 05:33 PM
which way is the correct procedure to bleed brakes? 91akira Acura Integra 5 10-27-2008 04:30 PM
How to bleed cooling system on D16Z6 Falcon10 Honda Civic / Del Sol (1992 - 2000) 2 01-31-2006 04:07 PM
Proper way to bleed the coolant system....... JV Tech / Misc 2 04-19-2002 02:22 PM
Tags
1992, 2002, 93, accord, air, bleed, bleeding, blleding, capacity, coolant, cooling, fit, honda, prelude, radiator, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
