Bleed hydraulic clutch 92 Accord LX 4dr : Slave Cylinder - Honda-Tech
Old 10-11-2006, 11:09 AM   #1
New User
mhuffs9017's Avatar
Default Bleed hydraulic clutch 92 Accord LX 4dr : Slave Cylinder
My accord sat for 2 years. I recently went to start it and the clutch pedal went pretyy close to the floor. However, it stil works a bit, but the car is always in gear if I start it up in first. The clutch resoivoir was empty so I'm presuming that some air got in. How do I bleed the system? Where is that bleeder valve located? Where is the slave cylinder? If anyone can help, I would tremendously appreciate it.
One more, how do I replace the water pump without dropping or raising the engine? I did the timing belt about 4 years ago but didn't hit the water pump.
Any and all responses are great. Thanks!
Modified by mhuffs9017 at 11:37 AM 10/11/2006
mhuffs9017 is offline   Reply With Quote
Old 10-11-2006, 06:45 PM   #2
JimBlake's Avatar
Default Re: Bleed hydraulic clutch 92 Accord LX 4dr : Slave Cylinder (mhuffs9017)
The clutch slave cylinder is on the front of the tranny, about mid-elevation, close to the radiator fan. Also close to the split line between engine block & tranny. The bleed screw is on the slave, pointing sorta upwards.
Loop some string around the clutch pedal, so you can pull it back up while pumping it. Put a hose on the bleed screw & put it in a bottle. Get a friend to pump the pedal.
1 - Pump the pedal & then hold it down.
2 - Open the bleed screw a bit, close it immediately when fluid stops flowing.
3 - Use the string to raise the pedal, it won't spring up on it's own. Control it with foot, DON'T let it snap quickly up.
Repeat 1 - 2 - 3 for a bunch of times, while watching the fluid level in the reservoir. Don't let it go empty!
When the fluid coming from the bleeder is fresh & clean, you're done.
The water pump was right there when you replaced the timing belt. It was the 'other' toothed pulley, real close to the smooth tensioner pulley. If you get the tensioner out of the way, there's a small handful of bolts around the waterpump pulley; that's all you needed to do. Doing it now requires removing the timing belt again, so you may as well get a new one since it's been 4 years.
JimBlake is offline   Reply With Quote
Clutch hydraulics issues Mark Segree Honda Civic (2001 - 2005) 2 02-17-2016 05:14 AM
Problem Bleeding CRV (put old Master back in, and it works) citrano1 Honda Element & CR-V 0 01-17-2012 06:10 AM
no clutch pressure. 94 eg d16z6 bannacrx Honda Civic / Del Sol (1992 - 2000) 4 05-25-2010 01:13 PM
clutch line is leaking Gangsta8957 Honda Prelude 3 11-03-2009 05:53 AM
Clutch Line Leaking at Slave Cylinder rhdins Honda Civic / Del Sol (1992 - 2000) 1 11-03-2009 04:22 AM
Tags
1990, 90, 92, accord, bleed, bleeding, civic, clutch, cylinder, honda, hydraulic, located, mhuffs9017, prelude, slave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
