Best grease for window rails? - Honda-Tech
Old 03-05-2007, 03:45 PM   #1
A Tribe Called Honda's Avatar
Default Best grease for window rails?
I've seen several posts on here for slow moving power windows on 94-97 Accords with several different opinions. Before I buy a new window motor for the drivers door, I'm gonna try and grease the rails. I'm wondering what the best grease or lube is to use on the window tracks/rails?
A Tribe Called Honda is offline   Reply With Quote
Old 03-05-2007, 03:50 PM   #2
philadd's Avatar
Default Re: Best grease for window rails? (A Tribe Called Honda)
I've always used white lithium grease (spray). Others like Shin-Itsu (sp?) grease.
philadd is offline   Reply With Quote
Old 03-05-2007, 04:07 PM   #3
ate my pixel
Twixle's Avatar
Default Re: Best grease for window rails? (philadd)
there's already a bunch of threads on this....but I use white lithium also. Just be sure and clean the tracks beforehand.
Twixle is offline   Reply With Quote
Old 03-05-2007, 04:07 PM   #4
hondadude's Avatar
Shinitsu is good if you clean out the window run channel and rub it in good.
Silicone sprays work well, if you keep using it. Doesn't seem to last as long as silicone grease [Shinitsu]
Also Dow Corning '77' is a light weight silicone grease.
hondadude is offline   Reply With Quote
Old 03-05-2007, 04:14 PM   #5
Default Re: Best grease for window rails? (hondadude)
Shinitsu sounds like the right stuff for the job. Is this something I can find readily available at my local auto parts store or is it a specialty item?
Old 03-05-2007, 05:18 PM   #6
BLKFLSH's Avatar
Honda dealer should have it. Auto parts store ????
BLKFLSH is offline   Reply With Quote
Old 03-06-2007, 12:21 AM   #7
pos_cd5's Avatar
Default Re: Best grease for window rails? (BLKFLSH)
i just recently used silicone spray. worked wonders! cant comment on durability, its only been a couple weeks.
but a tip, dont over do it! a little is enough. i completely saturated my **** and my interior smelt liek it for a week and amde me feel really sick breathing in all those fumes.
pos_cd5 is offline   Reply With Quote
Old 03-06-2007, 01:33 PM   #8
Heat's Avatar
Shin Etsu silicone grease costs about $16 at the Honda dealer for a 100 gram tube, about the size of a tube of toothpaste.
Or you can buy it online, one place that sells it is http://www.handa-accessories.com:
You can see it at their site near the bottom of this page, it costs $12 through them plus shipping (ground only):
Click on the link below to see a picture of what it looks like:
http://www.handa-accessories.com/shin.jpg
Heat is offline   Reply With Quote
Old 03-06-2007, 02:18 PM   #9
Default Re: Best grease for window rails? (pos_cd5)
Ok, cool, I'll check that out...Thanx guys!
Quote:
Auto parts store -- i.e. Schucks, Autozone, Napa, Checker...etc...
My passenger window rail?? sixtoek Honda Civic / Del Sol (1992 - 2000) 3 11-02-2012 10:29 PM
hard to roll up/down manual windows beav Honda Civic / Del Sol (1992 - 2000) 6 08-25-2007 03:14 AM
Caliper Rebuild Kit Grease Packets - What is What? Flux Acura Integra Type-R 5 09-29-2005 08:19 PM
window keeps falling off rail i HAVEtheADVANtage Honda Civic / Del Sol (1992 - 2000) 11 02-17-2003 12:23 PM
Should I ever grease the lugnuts? LudemanDan Tech / Misc 13 10-13-2002 06:35 PM
Tags
acura, auto, buy, etsu, grease, honda, lubricant, motors, shin, shinetsu, shinitsu, silicone, silocone, tracks, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
