battery not charging, but both battery and alternator are good - Honda-Tech
Old 03-25-2015, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 02-11-2011, 06:36 PM   #1
davey5300's Avatar
Default battery not charging, but both battery and alternator are good
So I was changing the rotors, pads, passenger side Upper control arm, and drivers side lower ball joint on my 1991 Accord DX 2 door (F22A1), and now the car keeps dimming and dieing. The battery isn't charging from the alternator at all. I know the battery is good because when I charge it with the charger box, it starts up and runs like a champ till dims and dies, and I know the alternator is good because I had it tested, plus I also replaced it with another one I had laying around which was perfect before I pulled it out of my old accord. I don't know what else to check out. In case it means anything, when I changed the upper control arm, I had to move the fuse box out of the way. Any advice is appreciated because I'm real frustrated right now
davey5300 is offline   Reply With Quote
Old 02-11-2011, 06:40 PM   #2
Default Re: battery not charging, but both battery and alternator are good
Check voltage at the terminals while the car is running. If it is receiving a minimum of 14 volts, the battery can't hold a charge and needs to be replaced.
However if the car dies while it is running, this is typically a sign of a bad alternator. Report back after you've tested the voltage the alternator is generating while the vehicle is running.
beeseeries is offline   Reply With Quote
Old 02-11-2011, 06:51 PM   #3
Quote:
When doing the right/pass side arm, did you happen to move the fuse panel?
poorman212 is offline   Reply With Quote
Old 02-11-2011, 07:04 PM   #4
I would say davey, check all your connections at the fuse block. most likely if it was working before, then that means that something went wrong in that process. did you disconnect the battery before messing around with the fuse box? if not, you couldve shorted something accidently. if you did, then good. maybe its as simple as just some wires not hooked up, or a blown fuse.
gregp09 is offline   Reply With Quote
Old 02-11-2011, 07:23 PM   #5
Quote:
Guess I should learn to read better. The OP stated they moved the fuse box and I skipped right over that....gregp09....thanks
Old 02-12-2011, 12:26 PM   #6
davey5300's Avatar
Well after long hours, changing the alternator again and a new battery, I finally figured it out!!!! The was a loose wire in the big wire harness that comes from where the ECU is. The wire was black and yellow
Old 04-12-2013, 06:07 PM   #7
hey whats up davey5300 i have a 1995 accord wagon witch i did a h22 swap the car was running fine up to about a week ago i put both a new batt n alternator then the same problem u had im having both items r good but when i turn the car on n i take off the batt terminal the car shuts off where exactly did u find the problem on the wire was it behind the fuse box or under the dash by the computer cause now that u mention about the fuse box i did take it out also when i replaced the arm n i also took it out when i did the lowering springs so if u could tell me exactly where the wire runs so i could save some time n headach or if theres maybe a relay or fuse thati may have over looked
jaysonant2 is offline   Reply With Quote
Old 04-14-2013, 01:48 AM   #8
The black and yellow should go through the shock tower connectors.
holmesnmanny is offline   Reply With Quote
Old 05-24-2013, 11:21 AM   #9
hey.. Ive got same problem but i couldnt understand how you solve it.. could you send a picture with that wire problem?
rudis_nartiss is offline   Reply With Quote
Alternator/Battery Charging problems Doreen Bellamy Honda Accord (1990 - 2002) 3 03-25-2016 01:03 PM
Alternator bad???? boostinb18c1 Acura Integra 13 10-11-2011 02:59 PM
Battery on car appears almost ....how do you know if its battery or bad alternator? hondaracin24 Honda Accord (1990 - 2002) 4 05-30-2005 09:17 PM
Bad Battery affecting alternator while on driving? Slammed Ek9 Honda Civic / Del Sol (1992 - 2000) 3 05-02-2005 01:06 PM
Engine power dying....alternator? Fobstylez Honda Accord (1990 - 2002) 8 07-06-2002 03:11 AM
Tags
87, 89, 92, 95, accord, alternator, battery, charge, charging, fuse, good, hold, honda, passes, test, tested
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
