Battery drains and car dies while driving
#26
Re: Battery drains and car dies while driving
Got it Werdnaegni.. I will check that too, thanks..
Cheers..
Cheers..
#27
Re: same problem
bryan0, did you ever solve this problem? My car is doing the exact same thing....
I'll be driving, the clock will dim, the seat belt will start beeping the radio will turn off, the guage needles will go crazy, and the car will die. I had the battery and alternator checked and they are fine. The car will start up after a jump, but will run for a short while then the same stuff happens. The Honda tech didn't know what was wrong. They said to bring it back if it happened again...
Did u ever figure out what the problem was because I have the same issue as we speak and I’m tired of getting stranded somewhere and callin triple a to tow me please respond as soon as possible thank you aj
#29
I have a 93 Honda accord it will just kill on me and I noticed when the car kill it drains the battery. I have the radiator replaced, the left fan, main relay switch replaced and I also had bought a new battery and post and I had the fuel pump checked and alternator and it's good and also I noticed when the car getting ready to kill it like pull back or losing power amd now the check engine light is coming on I'm a single parent and I desperately need to get this problem fixed
#30
I had some problems before and put them in this thread:
https://honda-tech.com/zerothread/2362061
The car is a 1996 Accord LX 4cyl non-vtec automatic with 80k miles.
There was a perfectly good battery in it, 2 CEL's came on (insufficient EGR lift and heater O2 sensor (see above thread)) and shortly after the car's gauges stopped moving, the lights dimmed and eventually it turned off. There was not enough battery power to get the engine to turn over or even "click." The alternator was tested at autozone and they said it was okay, I replaced the battery which they said was no good.
The next day the same thing happened. I started the car, the CEL's came on and the gauges went out, the lights got dim, and it eventually died. This is with a brand new battery!
Where can I start here? I cleaned out the EGR runner and valve, checked vacuum lines like 20 times, checked O2 sensor resistance. I searched on google, someone said something about replacing the ignition control module? It's like $100 though so I don't want to do that unless it's the problem for sure.
If I were to break down and bring it to a mechanic, do they have equipment that would tell them if there's a electrical leak somewhere which could be draining the battery?
Also fyi the car sit overnight with a full battery and lost no power. The battery only drains when the car is running.
Thanks
Edit: I just checked the spark plugs, 3 are SOAKED in oil I'm going to autozone to buy a valve cover gasket and new plugs. I don't think that's the problem though.
Modified by bryan0 at 7:30 AM 8/10/2008
Thanks
Nick K
01-30-2014 01:05 PM
chinoty
02-06-2007 04:49 PM
bozoka45
12-27-2004 05:21 PM
HybridHatchC1
22
12-11-2004 10:35 PM
