JDM DOHC F22B Engine... Will an H22 tranny FIT?
I hear pretty much all F/H series parts are interchangable, but someone was telling me I would need to make a custom bracket to mount the mid shaft onto the engine of the F22B if I used my H22A4 transmission from my 97 prelude?
He mentioned something about the F22B having a similar traction control setup similar the the SH prelude with ATTS/
is this true? Or would my NON SH prelude tranny bolt up fine with no issues.
1 Post
Re: JDM DOHC F22B Engine... Will an H22 tranny FIT? (Vt4cPwn35)
f22b does not have ATTS...that was on the 5th gen prelude...the F22B DOHC motor is a much older motor. as said before, its based off of the H23, and just uses a different designed head manifold, and bore.
from what i have come to understand is that ALL H and F trannies/axles will line up in some way shape or form (axles somtimes as a "hybrid" of parts), unless of course you have an H22A7 w/ ATTS...in which case you just need the entire drivetrain and the ECU
Re: JDM DOHC F22B Engine... Will an H22 tranny FIT? (fw190bvi)
Ok good to know, because the guy says he has seen this similar setup on euro accords as well, so I was a little puzzled thinking it was gonna need some custom fab to mount the mid shaft on.
RExLUdER
11-08-2002 04:21 AM
