Old 03-25-2015, 12:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
bad hesitation problems 98 accord
Old 12-14-2011, 12:16 PM
  #26
Hilt37Vtec's Avatar
Default Re: bad hesitation problems 98 accord
only smokes if i floor it at like 5-6 rpm, would this tell you anything.. if it starts hesitating while im driving i can shut the car off wait like 5 seconds turn it back on put it in gear and bam it fixes it for a while.. sometimes it doesnt though.
Old 12-15-2011, 05:16 PM
  #27
Hilt37Vtec's Avatar
I have no idea if this has anything to do with it but i just noticed the valve cover has missing bolts and a broek one... i didnt notice this when i bought it a couple months ago... does anyone no the stock size of bolts for the f23a1 valve cover..
Old 12-15-2011, 06:13 PM
  #28
Hilt37Vtec's Avatar
Any ideas?
Old 12-15-2011, 06:24 PM
  #29
JamesB1985's Avatar
I don't think anyone mentioned Throttle Position Sensor yet. Sometimes there can be a glitch on the grid inside the sensor. This can be checked with a multimeter to. You need to see a constant increase/decrease in voltage to make sure there is no dirt, scratches in there.
I haven't read every one of the symptoms you've listed but this came to mind.
I think you said it happens when its cold too? If you warm is up it runs fine? My 98' Acura CL will run fine once warm but buck when its cold because of a warn out transmission, but then again, that's an automatic.
Definitely check fuel pressure like everyone else said.
Also you can look up that bolt size for the valve cover..check out bernardiparts.com or google Bernardi Honda Parts. They have diagrams/pictures of the engine and you can pick out which parts you need.
Old 12-15-2011, 06:48 PM
  #30
Hilt37Vtec's Avatar
so where is the fuel pump on my car? in trunk or under rear seat? anyone know?
Old 12-15-2011, 07:40 PM
  #31
jdowen2's Avatar
Per the FSM: 1. check fuel pressure. 2. inspect and test throttle body 3. inspect/adjust throttle cable
Old 12-15-2011, 07:54 PM
  #32
jdowen2's Avatar
Fuel pump is in tank, filter screen is on the bottom of the pump. You could also have a bad fuel regulator.
Old 12-15-2011, 09:03 PM
  #33
Hilt37Vtec's Avatar
well i know its in the tank... but where is the panel to access under the rear seat or trunk?
Old 12-15-2011, 09:40 PM
  #34
phillyhonda's Avatar
Same thing happen with my accord but my check engine lite came on I checked the code It came back to a misfire I reserched be4 buyin any parts i read of guys buyin all types of parts and still didn't fix the problem as I keeped reading dude said he changed is altinator after buyin new pump,wire,plugs,distributor,filters and fixed it so I did to and fixed the problem
Old 12-16-2011, 07:59 AM
  #35
bdmlilburn's Avatar
you definitely want the valve cover bolts to be replaced. when you say one is broken where exactly is it broken? have you troubleshooted the egr system yet?
compression check wouldn't hurt
Old 12-16-2011, 08:55 AM
  #36
Hilt37Vtec's Avatar
ok i was testing out my car today and i let it get to running temp.. then i put the throttle to 2 rpm and held it there for a good 1 or 2 minutes then it just starting misfiring/bogging but i held the throttle exactly the same and it went down to like 1.2-1.5 rpm and it just sounded like bogging then when i let off the throttle it shot down to like 150-200 rpm almost killed it but then idled fine..... does that tell anyone anything?
Old 12-16-2011, 09:14 AM
  #37
do you have a check engine light on??
Old 12-16-2011, 09:44 AM
  #38
Hilt37Vtec's Avatar
no...
Old 12-18-2011, 06:01 PM
  #39
JamesB1985's Avatar
Drive it off a cliff. Nuff said
Old 12-19-2011, 11:24 AM
  #40
Hilt37Vtec's Avatar
i feel like it..
  #41
Hilt37Vtec's Avatar
shoulda just kept my chevy 1500.. damn imports
Old 12-19-2011, 11:35 AM
  #42
brakedrum's Avatar
How many miles does your Honda have on it? Is/are the Oxygen Sensor(s) original. It's more unusual for OBD2, but on OBD1 the o2 sensor can fail and never throw a CEL. It leads to the very kind of barely-drivable bogging that you described.
Old 12-23-2011, 12:52 PM
  #43
Hilt37Vtec's Avatar
it does it more when there is less gas in the tank? thats gotta be the fuel pump right?
Old 12-23-2011, 12:58 PM
  #44
PT-Tuner.com's Avatar
ok i have all the symptoms down to the wire.. i put a new cap and rotor on the car and it doesnt do it when its cold now.. now when it gets to running temp about 60 to 80% of the time it will hit 2.5 to 3 rpm and start losing all the motors power.. it will do it untill i absolutely floor it then it just all the suddens bucks and lunges forward untill i shift into the next gear and it does it again. if i shut the car off at a stop sign really quick and restart it sometimes that helps.. any ideas will help its driving me crazy! ive heard of other people having these symptoms but it seems know one finds the problem or atleast they dont post it.
If anything this sounds exactly like my experience when my oxygen sensor on my 91 accord went bad. When the engine is cold, the engine is running off basemaps and not using the feedback from the oxygen sensor. When you WOT, it ignores the o2 sensor. Otherwise when was the last time your egr ports were cleaned, as your issue is happening during "cruise"?
Old 12-23-2011, 01:00 PM
  #45
Hilt37Vtec's Avatar
it happens when i just drive regular and hit a certain rpm it starts bogging down and then it jerks and starts driving normal again
Old 12-23-2011, 01:12 PM
  #46
At least with my car when the issue happened, I found out it was the o2 sensor by simply unplugging it. With it unplugged the issue went away, yeah I had a check engine light, but the car didn't bog anymore. So maybe you could try that to rule out the o2 sensor. Otherwise you should be able to get a denso o2 sensor from rockauto for cheap.
Old 12-23-2011, 01:13 PM
  #47
Hilt37Vtec's Avatar
So would autozone be able to check if there are any stored codes? because i don't know if the guy i bought it off of erased codes or not?
Old 12-23-2011, 01:14 PM
  #48
Hilt37Vtec's Avatar
Which o2 should i unplug? the one at the header or behind the cat?
Old 12-23-2011, 01:20 PM
  #49
Hilt37Vtec's Avatar
any idea on which o2 sensor?
Old 12-23-2011, 01:28 PM
  #50
Try the one at the header first.
Quick Reply: bad hesitation problems 98 accord
