K&N Filter?
K&N Filter?
Hello I was wondering should I replace my OEM air filter to the K&N air filter w/o the cold air intake stuff just a replacement?
Are there any difference or suggestions out there?
Re: K&N Filter? (The-Kid)
does the K&N filter mess anything up? cuz i have a friend installed a stock replacement air filter & it messes up his Mass Air Flow Sensor????
He knows where you live!
Re: K&N Filter? (dragonle87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 »</TD></TR><TR><TD CLASS="quote">does the K&N filter mess anything up? cuz i have a friend installed a stock replacement air filter & it messes up his Mass Air Flow Sensor???? </TD></TR></TABLE>
Your friend fails at the internet.
Personally not worth it.
But a CAI or SRI from like AEM and be done, or get a ghetto ebay one and toss a K&N filter
Re: K&N Filter? (TheMuffinMan)
It's worth it if you don't feel like getting an aftermarket intake. and still wants to raise some MPGs... stock replacement is good for you. Plus you don't have to waste $$$ on replacement filters.
THE MAF thing is a big hoax. K&N tested this and there was no sign of K&N oil on the MAF. It was covered in silicone from the MAF sensor seal. 90-02 Accords do not have a MAF sensor anyways.
If u want to do it Muffinman's way... The ebay option is great. I got my AEM CAI for my 96 Accord for about $55. Used, but it's in pretty goood condition.
The MAS can be affected if your ECU doesnt pick up the changes and componsate for the gained air flow. That happened to my car, but all i did was take out the main ECU fuse for 30 seconds and put it back in.
This should reset everything and the ECU you catch up and recognize the difference.
Re: (dragonle87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 »</TD></TR><TR><TD CLASS="quote">Buy a CAI or SRI from like AEM and be done, or get a ghetto ebay one and toss a K&N filter</TD></TR></TABLE>
I agree man look its money well spent....its just a simple bolt on and its something you can personally installed....take pride in your ride.
1 Post
Re: (Grandhustleman86)
i was thinking the same thing. since when have accords used a MAF. second, it will be more effective getting a k&n filter with a cheap ebay tube instead of a 200 intake that basically will be the same as the cheap stuff. CAI's are iffy. depends on your climate. if you get alot of rain/flooding, skip the CAI and do short ram.
Re: (dragonle87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 »</TD></TR><TR><TD CLASS="quote">really the accord doesn't have a MAF???
then how does it perform the amount of air going into the engine? </TD></TR></TABLE>
it uses a MAP sensor. i also read about the MAF problem with K&N filters, overall from what i have read i believe it to be false, and a easy excuse for the dealership to point fingers. but who knows.
as far as the drop-in filter, i say its worth it definately. but the ebay pipe + K&N cone filter is another option too. really depends on what you want out of it.
