automatic transmission px4b drives in neutral
Old 08-16-2013, 10:24 PM
camry-man's Avatar
Default automatic transmission px4b drives in neutral
Ok so I have a 90 honda accord lx with a px4b A/T. Its jacked up shifts resly hard lunges when you shift in reverse and has no power at all. So im replacing it monday but today.
I shifted into neutral and took my foot off the brakes and I started to roll. Then I gave it some gas and off she went . I drove my car in neutral for 3 min.
I find this very odd how would this happen never have had this happen to me so any ideas of what it coild be.
Old 08-16-2013, 11:47 PM
holmesnmanny's Avatar
Default Re: automatic transmission px4b drives in neutral
I suppose the cable isn't adjusted correctly. Normally the neutral safety switch would prevent you from starting unless in neutral or in park but I suppose if it's really that badlly adjusted I suppose it wouldn't know.
This still sounds kinda hard to believe.
Old 08-17-2013, 02:23 PM
camry-man's Avatar
it only starts in park. im saying i start my car in park shift into neutral and take my foot of the brake it starts to roll like im in drive. im replacing the transmission on Monday im just trying to find out what would cause this to happen. i will post a link to a video of me driving with the car in neutral gear. but i have to go to work right now
Old 08-17-2013, 07:42 PM
MM Gruppe B
MAD_MIKE's Avatar
When you shift into Neutral is it actually Neutral or are you solely going by what the shift indicator is showing?
Without looking at the shift indicators, place the car in Neutral from Park > Reverse > Neutral. What is the indicator showing? What does it show in all other gears?
The shift cable can become maladjusted and need readjustment. Click on the Techauto link and look up shifter adjustment.
Old 08-18-2013, 10:23 AM
camry-man's Avatar
Hear is that link its kinda crappy
Old 08-18-2013, 09:24 PM
MM Gruppe B
MAD_MIKE's Avatar
The video just shows that the shift indicator on the dash shows 'N'. But that doesn't mean much.
If you can answer these questions it would be helpful...
Also...
Can you shift from Park without depressing the brake pedal?
With the car OFF can the shifter be moved without having to use the override?
Can you shift into other gears? If so can you select D1 and does it indicate '1' on the indicator?
Have you had any recent work done? White faced gauges are not factory.
Help us, help you.
Georgio
Transmission & Drivetrain
12-01-2012 08:00 PM
debbie49
12-17-2011 04:52 PM
FreshCD5
02-25-2010 11:55 PM
lowered94accord
09-13-2006 04:48 AM
doeboy6587
04-03-2006 10:02 AM
Quick Reply: automatic transmission px4b drives in neutral
