Auto trans 1st gear slipping? - Honda-Tech
Old 09-09-2009, 08:46 PM   #1
tpot90's Avatar
Default Auto trans 1st gear slipping?
My 6th gen 2.3 AT (with 102k) is starting to struggle deciding which gears to use from 1st to 2nd gear while slowing down then accelerating @ speeds around 10-15mph. If I accelerate hard in first gear, it will slip and over rev a little bit before it gets into 2nd. I can mostly avoid that problem by letting off the gas a little before it upshifts.
I am well-aware of the 6th automatic transmission failure rate, so I wont be suprised to hear if my trans is failing. *No blinking D4 light. But I've heard talk about "solenoid issues" that can cause these problems. Also, my automatic trans class instructor spoke about solenoid issues in Accords.
So I want to hear from HT what everyone thinks. If these solenoid problems could be solved, then it would save a lot of time & effort. How should I troubleshoot this problem?
tpot90 is offline   Reply With Quote
Old 09-09-2009, 09:18 PM   #2
Default Re: Auto trans 1st gear slipping?
thats what mine was doing in my old 6g before the auto went. thank god i sold it before it blew up, hahaha.
Sketch o5 is offline   Reply With Quote
91 civic auto trans shift problems and surging idle steevano Honda CRX / EF Civic (1988 - 1991) 3 12-15-2014 09:43 AM
98 V6 Automatic transmission problem MeDuncan Honda Accord (1990 - 2002) 2 10-24-2014 05:04 PM
shift solenoids causing issues on 99 Prelude automatic? RyanA Transmission & Drivetrain 2 09-12-2009 05:26 AM
94 civic auto trans not shifting right, shift solenoid?? fastrecklessracer Honda Civic / Del Sol (1992 - 2000) 0 12-22-2008 04:38 PM
Will 2002 accord auto trany fit to 1998...? TK_Accord Honda Accord (1990 - 2002) 1 04-10-2007 12:28 PM
Tags
1st, 2001, 2002, 2nd, accord, auto, failure, gear, gears, honda, problems, slipping, slips, solenoid, trans, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
