Auto Tranny Fluid Flush
Old 09-16-2002, 05:15 PM
New User
ModlesSI's Avatar
Default Auto Tranny Fluid Flush
Hi, im use to changing fluid on my manual tranny, but im going to be changing the tranny fluid of an '01 Accord EX i-4 this week... I think its a little different from my manual tranny. Can anyone explain to me what i would need to do to flush the auto tranny fluid? thanks in advance!
Old 09-16-2002, 05:21 PM
Art Vandeleigh's Avatar
Default Re: Auto Tranny Fluid Flush (ModlesSI)
i think it is the same...but im not sure. i guess i didnt really help huh...i hope someone else will come in on this, cos i would like to know too.
Old 09-16-2002, 05:38 PM
Razor's Avatar
Default Re: Auto Tranny Fluid Flush (up-youRs)
theres a auto tranny drain bolt to the left of the oil drain bolt and you just open it and let it all come out. tighten it up, and pour like 3 or 4(im not exactly sure) of honda atf through the engine bay tranny dipstick hole. make sure its honda aff, it works best.
Old 09-16-2002, 05:41 PM
New User
ModlesSI's Avatar
Default Re: Auto Tranny Fluid Flush (Razor)
Thanks alot! So the drain bolt is not on the side of the Auto tranny like manual trannys?
Old 09-16-2002, 06:51 PM
Razor's Avatar
.no its not. see i have access to a lift at my job and it makes things easier. once you jack up or lift the car up, you will easily see the bolt under the tranny. good luck and remember to always use honda atf .
Old 09-16-2002, 07:00 PM
Gen4-5Door's Avatar
The drain plug looks the same as a manual trans drain plug. Similar service, just easier to fill. I agree, use Honda ATF.
Old 09-16-2002, 07:25 PM
GZERO's Avatar
It would be like 4 if you don't touch the turbine, if you do the turbine it would be like 9
Old 09-17-2002, 01:22 AM
does the car need to be level or can you just jack up the front? thanks!!
slatermvp
04-13-2012 04:17 PM
ragnarok0mega
08-01-2010 06:32 AM
egyolk
04-29-2005 12:33 PM
GDM93Si
12-31-2004 09:05 AM
DrunkNRacer
05-08-2003 11:45 AM
Quick Reply: Auto Tranny Fluid Flush
