Auot gear shift is hard to get out of park and back in - Honda-Tech
Old 06-03-2008, 10:58 AM   #1
gowings's Avatar
Default Auto gear shift is hard to get out of park and back in
I have searching threads looking for an answer or diagram as to why my son's 1990 Accord coupe auto transmission is hard to get out of park and back in at times. Once I get past park everything is smooth. The tranny shifts fine etc. It's just sticky trying to move in and out of park. Anybody pointing me in the right direction would be appreciated.
gowings is offline   Reply With Quote
Old 06-03-2008, 04:03 PM   #2
Mr Yamada's Avatar
Default Re: Auto gear shift is hard to get out of park and back in (gowings)
Two things could be the cause of this problem, The shift inter lock is out of adjustment or the solenoid is not fully retracting.
Secondly, the Shifter cable that runs under the car to the transmission.
If you remove the center console the fault should be easy to find.
Mr Yamada is offline   Reply With Quote
Old 06-04-2008, 09:52 AM   #3
wch
wch's Avatar
I had this exact same problem for about a year. Then on a long road trip it got worse, and then I lost reverse, neutral, D4, and eventually D3. It turned out that the problem was the shift cable, and replacing it fixed all the problems. I think it's usually called the "AT selector cable."
Here's the thread:
http://www.honda-tech.com/zerothread?id=2297828
wch is offline   Reply With Quote
problem shifting from park to reverse 95 accord glen123 Honda Accord (1990 - 2002) 1 10-08-2016 06:48 PM
1990 Honda Accord LX Coupe, Brake Caliper Bad? cholder919 Honda Accord (1990 - 2002) 7 08-16-2014 05:19 AM
2002 Odyssey shifs to easily bruceb Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 12-24-2010 03:15 PM
Shifter was sticking in park now won't go in park! idewson Honda Accord (1990 - 2002) 0 09-08-2007 01:59 PM
cannot shift into park icedaccord19 Honda Accord (1990 - 2002) 3 02-16-2006 06:16 PM
Tags
1990, 1992, accord, cable, civic, gear, hard, honda, park, problem, reverse, shift, shifting, solenoid, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
