Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Why is My Car Squeaking?
Guide to diagnose trouble and recommended solutions
Annoying Squeaking Noise in Suspension
#26
Re: Annoying Squeaking Noise in Suspension
Went to the JY Sunday and pulled a lower control arm and installed on drivers side. Instant change. No more squeaking on that side so that verified that it's the bushings gone bad. Will be buying some bushings and installing on both control arms soon. Just a update...
#28
#29
I wish it was a way but I just replaced both while I was there. Next time I will replace the lower ball joints first, then go from there.
#30
I had this same annoying noise, turned out to be the strut/radius rod bushings. Was hard to pinpoint. But when I tore down the knuckle and strut assembly, I inadvertantly pushed down on the lower control arm, and it squeeked, and with the knuckle out of the way I could easily get my head in there and hear it. So, that pinpointed it for me. I sprayed some kroil(Liquid magic) on them, they shut right up. Will replace, if they start acting up again.
#31
hi, I am experiencing a squeak too, coming from my front passenger suspension.
I added 2 links to the sounds that I am hearing.
Sound 1 - Loud Squeak (While driving fast on a bumpy road or while driving fast and turning at the same time) : http://www.mediafire.com/view/jt86y8...204%20Copy.mp4
Sound 2 - Subtle Squeak (While driving slow) :http://www.mediafire.com/view/o3qa7e...ording%205.mp4
Can anyone confirm that this is the same sound that they were hearing? If not does anyone recognize this noise. Btw I just changed my front shocks, bump stops, bellows and upper control arm ball joints.
However this is a photo of my lower balljoint. https://www.dropbox.com/s/vi2saxbg8f...2018.23.46.jpg. It looks ripped. Could this be the problem?
#32
I used quality replacement parts (Moog), replaced the lower BJ, the lower control arm mid and front bushings, stabilizer links, and wheel bearing on both left and right so sides might be matched. All items torqued to spec while loaded. What did I miss?? Did you spray in the throat of that LCA bushing?
Note: it definitely is temperature dependent. Thanks for any help.
#33
If djkurious is experiencing this noise while at a standstill (granted hes turning the wheel to make it) how likely do you think its suspension bushings?? c'mon guys haha
Try holding the steering wheel all the way to the lock in one direction with the engine running and then releasing the wheel, i'd be curious to see what this squeak bullsh*t is all about then. You could be hearing your power steering pump (A faulty pressure relief switch). Another test would be to test load the engine: Set the parking brake, put it in drive, put one foot on the brake pedal and give it like 2 second hold of the throttle. If you have a 5spd...its a little different:Set the parking brake, put it in 1st and work the clutch over its engagement point(playing with the engine rpms through the clutch pedal and avoiding an engine stall), listening carefully for the squeak.
Also, try to describe this sound a little better...Is it metallic? Like could it be a small movement between metal parts? Does it sound more like rubber? Does this sound remain a consistent velocity and tone?
It could be motor mounts as well, a bad exhaust hanger/break in system?? OR you might want to start looking into the the steering rack.
#34
Other stuff. Did a PS flush at last alignment, exhaust is fine. Also, compliance bushing replaced and oriented properly then (One was craked through)
#35
@HoopersGarage: Did you replace the upper ball joint/control arm? Groaning/creaking can be a symptom of a worn ball joint, i see you already replaced the lower.
Did you grease the compliance bushing when you installed it?
Have you replaced your sway bar bushings and end links?
When you turn the wheel while not in motion, the ball joints will definitely rotate so potential there; also, unless it's completely flat, you may get some relative movement in the compliance bushings and sway bar assembly.
#36
Your gonna have to get a buddy to help you listen and diagnose where this sound is coming from. Ball-joints are encased in grease and rubber so its rare that they get dry enough to wear out and start creaking. I would jounce the suspension with a friend to try and pin point the issue. Something tells me to look into the upper control arm bushings, it sounds like you've replaced or eliminated everything else.
#37
I'm glad you mentioned greasing bushings. I want to that but concerned that it mess up handling or torque. Do you place the grease in the bushing shaft and then reinsert the blot and torque under vehicle load weight? Thanks.
#38
#39
The upper control arms come as an assembly so I'm not sure if you need to grease them. It certainly won't hurt to try.
The compliance bushings and sway bar bushings should both be lubricated though. I personally like using white lithium grease in the tub (not the aerosol). It's easy on rubber and plastic parts, unlike some heavier chassis-type greases.
The compliance bushings should have a nice even coat of grease around them, where they contact the frame.
#41
Just to clarify in case its not obvious - the radius rod bushings, compliance bushings, and strut rod bushings are all the same thing.
#42
I hope to do tonight after heating the garage. We're having a brutally cold winter here.
#43
I'm not sure if greasing the lower control arm or strut bushings will do anything. If you look at their construction you'll see what I mean. The rubber is bonded to a metal sleeve on the outside and inside diameter, so there's no rubbing or sliding between the bushing and metal, or at least there shouldn't be. The rubber itself is deforming to allow for movement.
The radius rod bushings, on the other hand, sit directly inside the front cross member, and squeaking occurs when the bushings move relative to the cross member.
You are correct, though, that all bolts should be torqued to spec when dry threads and after the suspension is loaded.
#44
Sorry it took a few days to post an update. I greased the so called radius rod bushings, sound went away for ten miles then returned. I then used a mechanics' stethoscope to probe the front end. Loudest at link to LCAs and steering knuckle. I then disconnected the sway bars links at the LCAs and drove it around the block. No change so that rules out the whole stabilizer subsystem. So happens that I got a recall notice and will have dealer diagnose it for me tomorrow. Unless it's expensive I'll likely have them do the repair. More to come ...
#45
Masospagetti and goodusername -
#46
#47
Had that crazy squeak on my 90 Accord. Struts were leaking anyhow so replaced the complete strut again after replacing them 5 years ago (Lifetime warranty) So they were free. Same squeak. Noticed the ball joint boots were dried and cracked (139,000 miles)
Non greasable sealed units...So I stuck the spray tube from a can of spray lithium grease
into a small hole in the boots and instantly a quiet front end! Now I know its the ball joints for sure and not any of the many rubber bushings in that suspension.
#48
this post is almost 6 years old but do you remember what brand you used for the bushing? If it's moog the you remember the part # I'm having the exact same issue right now on my 03 Accord Coupe
#49
moog aint what it used to be imho.
their ball joints look pretty sketchy lately.
i'm running energy suspension, easy to replace
without special equipment (once you press the old
one out with giant c-clamp and adapter; free rental
with deposit at many part stores).
#50
If you installed coilovers already, I can't imagine them being blown already unless you bought some cheap ebay stuff. However, if it does it when going over speedbumps, then it could be.
Is it safe to assume you meant "coils" not "coilovers" ? If so, then it's probably the shock being blown afterall.
