Alternator Removal issue
Hi i was replacing my alternator and the bottom thru bolt is siezed. I have removed all things like Power Steering, cruise. But I can not for the life of me get the alternator belt off. I have loosened and even removed the adjusting bolt and loosened the nut that goes on the bottom through bolt but still I can't get it off. What am I doing wrong? Does anyone have a way to fix this?
I cant relieve the tension on the belt.
1991 Honda Accord LX
Is it possible to remove the top alternator bolt then tilt the alternator to the front then pull the alternator off of the bottom bolt?
Re: Alternator Removal issue
so you removed every bolt but the bottom through bolt? place a block of wood on top of the alternator to protect it and hit it with anything blunt/heavy. it should slide down. i have had a few instances where these things get stuck like this
a swift kick has also been useful to me when removing seized parts but never had to go this far with anything as small as the alternator
So your just saying to jar the alternator free? Hit the TOP of the alternator down? Will that loosen the belt as well? Thanks I really need to know by tomorrow because it is the last day I have.
Thanks I'll try it.
Thanks I'll try it.
no it is the top through bolt that that the alternator gets stuck in. it is a really tight fit which is why it can be hard to brake free. make sure the top bolt is installed but loose so that the alternator does not just fall when it breaks free.
i would be very careful spraying anything around the alternator. dont get anything inside it. if you cannot do it without the pb take a grocery bag and wrap the alternator to protect it from the spray. though it should break free just fine without the pb blaster with the proper amount of force. then you just have to shimmy it out of the mount by wiggling it up and down
keep the top bolt in just not tightened so that the alternator does not fall
impact gun..
ive came across a few alternator through bolts that wouldnt budge. so i brought out my snap on 1/2 inch gun.
The way the bottom through bolt is is it has as a 12mm nut and that is it. I have gotten the nut off but still can't remove it. The instructions I have said to loosen the adjusting bolt then remove the nut. The next step was to remove the belt. But I couldn't get the belt loose. The nut is on the divers side and on the passenger side of the alternator it is just a flat end. It is seized and there is no room.
We did try to knock it out with a screwdriver and a lead hammer but it started to bend the bolt.
Does this bolt control the belt tension?
regardless a bent bolt will need replacing
The bolt is seized in there. We couldn't hit it square because of where it is. Would it be easier to jack up the engine a little bit to hit the bolt? It makes no sense to me either, nothing holds it in, but the nut. The power steering has the same mechanism and I got it right out. I have the whole mechanism off of the alternator and I can't get the belt to loose any tension and the bolt is stuck.
I don't know why it isn't coming out.
Has anyone ever have this problem? The bottom through bolt which should just slide out is seized. I can't even loosen the belt the was it is. Please Help.
Is there anyway to get a pair of vise grips on the bolt and spin it just to loosen it?
I really need to have good way to remove the alternator by tomorrow. It is the last day I have and if I can't I am going to put it all back together and bring it to a mechanic, but everything went smooth until that one freaking bolt. Please Help Me!
post #420 smoke.....smoke.....are you smokin yet?
i dont think spinning it will work if knocking it loose did not work though it is worth a try. have you tried hitting on the alternator from the top with a rubber hammer or a block of wood and hammer. you removed everything that holds the tension so the alternator will move even when the bolt is still there. you removed the long 10mm bolt from the front/bottom of the alternator correct?
if you are crunched on time try to get a chisel on the bolt and see if you can chisel it free. perhaps a previous owner used some kind of epoxy to keep it from moving. again some photos could help us help you better. wd-40 or any kind of engine cleaner or degreaser or pb blaster/liquid wrench can be used on the area after the alternator is safely wrapped to protect it
Ya everything is removed but the belt is still on. I think i am going to try to remove the driverside engine mount and raise the engine to get a better angle at the bolt. I will also try to hit the top with a hammer and see if it knocks it loose. I'll write back to tell you how it went.
He knows where you live!
If it's seized and you tried soaking it with PB Blaster and hitting it with a torch and tried using a cheater bar then you need to go to air tools. You may want to consider replacing that hardware with some non-junked up stuff to prevent it from happening in the future.
Well the bottom through bolt is the one that is stuck and it just has a nut on the end it is then supposed to just come out, but it doesn't move and it is in a really tight spot not allowing me to get a torch in there. The belt doesn't even loosen with the tensioner mechanism out.
