Alarm System
Old 02-16-2007, 09:52 AM
honda94accord's Avatar
Default Alarm System
I have a 94 honda accord ex. It has a factory alarm system on it and i need to kno how to disable that. Cuz my key fobs both don't work and i can't find any new ones anywhere. And i can't drive the car without them. And i need it badly cuz i don't have any other mode of transportation. So does anyone kno what has to be done to disable the alarm on it?
Old 02-16-2007, 05:13 PM
The-Kid's Avatar
i never had a factory alarm before but, check for fuses? my aftermarket alarms are installed behind the dashboard.(look up from the pedals) sometimes its directly connected to the battery connector.
Old 02-16-2007, 05:16 PM
The-Kid's Avatar
check this PDF out. http://www.handa-accessories.c...y.pdf its the OEM alarm system, but its for a 98-02 Accord. Check all those. Should be almost the same.
Old 02-16-2007, 05:19 PM
hondadude's Avatar
Default Re: Alarm System (honda94accord)
awww man, bad deal; Honda deletes accessory information after 10 years; but I'll go look for 97 Accord schematics and see if I can get you any useful information.
FWIW there is an Ebay guy that sells all kinds of remotes.
EDIT:
I had a flashback that might help you; if you go along the front of the hood area and find the hood switch for the alarm system you can unbolt it and hang it down and tie it back with a wire tie. The system will never arm itself if it "thinks" the hood is open.
also you could put the system in 'Valet' mode;
Modified by hondadude at 8:39 PM 2/16/2007
buzzwiree
05-29-2018 08:01 AM
nhldogg
02-19-2010 02:14 PM
pixshooter
09-08-2009 01:48 PM
honda94accord
Audio / Security / Video
07-08-2007 03:00 PM
Gemini
05-22-2006 05:17 AM
Quick Reply: Alarm System
