Adjusted valves, but none needed it?
Old 01-09-2002, 10:29 PM
AggAccord03's Avatar
Default Adjusted valves, but none needed it?
I got in there and adjusted my valves for the first time tonight...BUT none of them needed adjusting...My car has 75K on it and they were all within spec. Is this normal?? I figured they would be all sloppy with the way I drive the car. Thanks.
Old 01-09-2002, 10:33 PM
New User
John's Avatar
Default Re: Adjusted valves, but none needed it? (AggAccord03)
sometimes you just get lucky....
Old 01-09-2002, 10:44 PM
smokin rubber's Avatar
you must not rev the engine enough ,
each day from now on run out first gear four times and second gear at least once
Old 01-09-2002, 10:52 PM
Default Re: Adjusted valves, but none needed it? (smokin rubber)
I drive it really hard - at least in my head I do...I still had to do the work though...oh well.
Old 01-10-2002, 06:06 AM
4doorH22's Avatar
Did you even losen any of the adjusting screws? Or just stick the feeler gauge in there after setting your crank angle correctly each time?
vtec@4000rpm
02-13-2012 08:27 AM
crxfreak88
03-10-2005 07:26 AM
1.7na
05-31-2004 07:12 PM
^jefs0ng
01-14-2004 05:55 PM
pub
06-13-2002 09:04 PM
Quick Reply: Adjusted valves, but none needed it?
