adjustable upper control arm??
my 94 accord has a bad upper left control arm and being lowered my camber is also way off and im chewing up tires. so my question is are there any companys that make adjustable upper control arm kits for the accord so i might be able to fix 2 problems at once?
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">never seen one yet
only seen adjustable pivot mounts and adjustbale ball joints for accords.</TD></TR></TABLE>
is it possible to make one?
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">im sure if you work in a machine shop and are creative you could.</TD></TR></TABLE>
i fall under neither of those categories so i guess i wont be having an adjustable control arm anytime in the near future!
Re: (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord »</TD></TR><TR><TD CLASS="quote">wouldnt spc ajustable ball joints do the trick?</TD></TR></TABLE>
SPC adjustable ball joint would help a little but if the camber is way off, you need a Full adjustable UCA.
OMNI powerusa made those but they do not have one for accord, only civic and teg
Re: (iam7head)
y not get a camber kit... that will atleast fix one problem.. i got my car lowered n im doin the same thing.. i dont feel like buying the kit either lolz..
Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">SPC adjustable ball joint would help a little but if the camber is way off, you need a Full adjustable UCA.
OMNI powerusa made those but they do not have one for accord, only civic and teg </TD></TR></TABLE>
with -3 degrees camber which is pretty damn off i was able to work it out fine with a set of ingalls pivot mount camber kits, though i did not correct much with the clerarance under the fender lining, for as often as most people adjsut their camber adjustable upper control arms really arent much of a need....
llW0PllNefRex
19
11-18-2003 07:40 AM
