Accord won't start after engine coil removed/replaced.
Old 06-18-2012, 06:56 AM
Parriss Stull's Avatar
Icon3 Accord won't start after engine coil removed/replaced.
My step dad removed my engine coil and replaced it, my car sat for two days. Now my car won't even kick strong. It turned over once and it had a low, weak sounding rumble for three or four seconds and died. I'm unsure what to do. I checked my oil and it seems fine, I checked my battery and its good. Idk what to do
Old 06-18-2012, 11:50 AM
GhostAccord's Avatar
Default Re: Accord won't start after engine coil removed/replaced.
What year engine/chassis are we talking here?
Internal or external coil?
Test the new coil. Not always 100% out of the box...... Also if you had to remove the spark plug wires for some reason, check to make sure they are back in the correct positions.
Check all of your battery + & - connections along with the ground connections on the engine and distributor housing.
ride5150
17
03-23-2011 10:54 AM
teg your it
08-23-2010 03:01 PM
aaabha
07-15-2010 01:17 PM
Spartanic
09-21-2003 08:25 PM
Charlie Moua
08-02-2002 04:50 AM
Quick Reply: Accord won't start after engine coil removed/replaced.
