accord radio wire harness
What color is +12 volt battery and memory? I checked on some site, they say it "(yel/red) (white, blue), but i couldn't find it on 96 dx accord. Hit me up
Re: accord radio wire harness (Bda91acc)
Bda91acc - I think he means on the actual Accord wiring harness, not just the aftermarket industry standard of red = 12v and yellow = memory.
To answer your question, you are gonna need a voltmeter of some kind and start ringing out the Accord harness wires. With the ingnition off, probe around and find the costant power wire. With the ingintion turned to "on", probe the wires and find the 12v source. The constant 12v source with ingnition turned off is memory and the other your switched power.
HTH
HTH
Re: accord radio wire harness (Hondaaccordvtec)
you can do it the red neck way...
go to autozone or kragen get one of those adapter, open the package and there's the color coded diagram and pin out, use it and return it..
dont know if all the honda have the same code, i still have my colored code when i install an aftermarket radio into my acura legend 1990
Re: accord radio wire harness (iam7head)
this dont really ahve to do with this but i remember a couple months ago my whole harness back there burnt up all becuase i put a piece of foil in one of the fuses, so the fuse never popped and everything burnt up the harness it self cost 675 bux from the dealer but a good frined of mine owns a junk yard and gave it to me for FREE and it cost me 450 bux to put it in what a stupid mistake...lol...so if u gon put foil in a fuse make sure u replace it immediately...and 12v is red in almost any kind of wiring that i can think of
Re: accord radio wire harness (ForceXVII)
go to your honda dealership and check out the wiring diagram. thats what i did they were nice enough about it
lol hey guys i am a professional installer and on the accord harniss the blue/yellow is memory, i kinda forgot what the switch one is but its easy to find out. just get a 12 volt tester and probe the wires, the one that turns on when the key turns on is the 12 volts switched and if its not the blue/yello than just use the tester to fin out which wire it is. this wire will stay on no matter what. this is the 12v memory wire.
YeuEmMaiMai
10-25-2005 08:09 PM
