Accord Jerks During 2-1 Downshift
Old 09-28-2010, 11:48 AM
Jer510's Avatar
Default Accord Jerks During 2-1 Downshift
I know that there are many posts about this topic and I've searched the forums for some answers but I felt like I needed a little more input. Sometimes when I'm driving during low speeds around 20mph or less, I notice a jerk when the transmission downshifts from 2-1. I have an AT 99 V6. It doesn't do it all the time. It only happens at low speeds when you are cruising and all of a sudden let go of the gas. Other than that, my car runs and accelerates smooth. Any suggestions? Also I've had the fluid flushed about 4 times since I bought the car in July with Honda ATF.
Old 09-29-2010, 04:11 AM
nhldogg's Avatar
Default Re: Accord Jerks During 2-1 Downshift
Tranny is going out. Flushing the fluid will help prolong the life but it is a waste of money after a while. Just start saving up and looking for a rebuild.
Old 09-29-2010, 09:15 AM
jdadams12's Avatar
Get rid of the Z1. The Z1 is an OK base that is full of Friction Modifiers that make for a smoother shift allowing the clutches to slip. This slipping will cause more wear, but does make for a smoother ride - which sells cars. This fluid is not good for trannys that already have some wear, since it causes more wear in it's self.
Replace the Z1 with some Synthetic Dex/Merc III. I use Mobil 1 or Redline D4 - the Redline is probably better, but the Mobil 1 is plenty adequate. The car will have a firmer shift with less wear.
You can use regular Merc/Dex III, but shifts will be more firm than the synthetic.
Mine used to do it on Z1 so much that I oftentimes just put the car in D2 in rush hour so that it did not do the 1-2, 2-1 shifting. Now, it is much better on the Mobil 1 Syn.
You might also test the second gear pressure switch... or replace it. No idea if that is the issue, but it might be causing the TCM to delay the shift. A bad pressure switch can cause really bad shifts both up and down.
wattsnow
11-15-2017 06:53 PM
SpazMan
10-21-2014 03:22 PM
stevo accord
05-02-2009 10:40 AM
masterkill455
02-20-2009 10:37 AM
Quick Reply: Accord Jerks During 2-1 Downshift
